[postgis-users] proj parameters from srtext?
Bernhard Reiter bernhard at intevation.de
Fri Apr 19 09:56:31 PDT 2002
Is there a standard procedure find out the proj4text values
from the srtext descriptions in the accompained spatial_ref_sys.sql?
Or will future revision of postgis' spatial_ref_sys.sql
contain the projections that proj can handle?
I assume there is no good tables for this
otherwise somebody would already have filled it. :)
	Bernhard
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020419/1cebec3a/attachment.pgp>
