[postgis-users] proj parameters from srtext?
Bernhard Reiter bernhard at intevation.de
Fri Apr 19 10:52:15 PDT 2002
On Fri, Apr 19, 2002 at 11:13:33AM -0600, Sean Gillies wrote:
> The Proj.4 distribution contains a file named "epsg" that has
> a mapping between EPSG codes (SRID) and the Proj.4 parameter strings.
> It's straightforward to create SQL commands from this file
> and update the spatial_ref_sys table with the appropriate values.
Good to know, I did'nt make the right match on this name.
> I guess that they are not including Proj.4 parameters in
> spatial_ref_sys.sql because they don't want to tie you to a
> particular version of Proj.4.
Paul's answer lets me assume that it was a god question to ask. :)
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020419/5137048b/attachment.pgp>
