[postgis-users] Re: C question, PG_RETURN_POINTER: GPC integration
Nicolas Ribot nicolas.ribot at scot.cnes.fr
Tue Apr 30 07:40:30 PDT 2002
Oooooopss !!
I made a mistake with attachements !
Here are the correct files
Sorry for the inconvenience
Nico
#include "utils/geo_decls.h"
#include "postgis.h"
#include "gpc.h"
// taken from gpc.c to avoid inclusion:
#define MALLOC(p, b, s)    {if ((b) > 0) { \
                            p= malloc(b); if (!(p)) { \
                            fprintf(stderr, "gpc malloc failure: %s\n", s); \
		            exit(0);}} else p= NULL;}
***************EXPOSED TO PSQL********************
Datum union_pg_pg         (PG_FUNCTION_ARGS);
Datum intersection_pg_pg  (PG_FUNCTION_ARGS);
Datum difference_pg_pg    (PG_FUNCTION_ARGS);
Datum sym_difference_pg_pg(PG_FUNCTION_ARGS);
**********CONVERSION GPC <-> POSTGIS types********
GEOMETRY*  scot_gpc_clipping      (POLYGON3D *poly1, POLYGON3D *poly2, gpc_op operation, int SRID);
GEOMETRY*  gpc_to_GEOMETRY        (gpc_polygon *p, int SRID);
void       POLYGON3D_to_gpc       (POLYGON3D *ppoly, gpc_polygon *p);
POLYGON3D* gpc_to_POLYGON3D       (gpc_polygon *p, int *rings, int num_rings, int SRID, int *size);
bool       is_ccw                 (double x0, double y0, double x1, double y1, double x2, double y2);
bool       contour_in_POLYGON3D   (POLYGON3D *ppoly, gpc_polygon *p, int i);
int        point_in_gpc_poly      ( gpc_vertex *P, gpc_vertex *V, int n );
bool       gpc_hole_in_gpc_contour(gpc_polygon *p, int c, int v);
char*      gpc_polygon_to_text    (gpc_polygon *p);
GEOMETRY* add_geometry(GEOMETRY *geom1, GEOMETRY *geom2);
// the error message generated by one conversion function: not used
char *error_message = "no error";
***************TEST ZONE**************************
// geo functions
Datum test_geogpc(PG_FUNCTION_ARGS);
// transformation functions:
void scot_gpc_read_polygon(POLYGON3D *ppoly, gpc_polygon *p);
//void scot_gpc_write_polygon(gpc_polygon *p, POLYGON3D *ppoly, int *ppoly_size);
POLYGON3D * scot_gpc_write_polygon(gpc_polygon *p, int *ppoly_size);
* File:		   scot_gpc.c
* Author:      Nicolas Ribot
* Date:        25 avril 2002
* Version:     0.3
* Description: Providing OpenGIS UDF for polygon manipulation:
*			   intersection, union, difference, symmetric_difference.
*			   Some useful method to achieve that:
*			   is_ccw, gpc<->postigs conversion functions
               based on GPC clipping library.
* History:     0.1 (25 apr 2002) Original definition with a test function
*              0.2 (28 apr 2002) Added ogis UDF, conversion functions. Testing.
* Bugs:        gps does not consider that a hole touching a contour at one point is a hole.
*              Opengis does... => with such objects, the resulting postgis poly will be
*              invalid.
* ToDo:        Manage objects deallocation
*              Provide a dynamic memory allocation for resulting postgis polygon
*              Write a debug function for gpc polygons (char*)
					-> done
*              Merge gpc_to_POLYGON3D_tmp code into gpc_to_POLYGON3D
					-> done
*              Implements a point_in_poly for gpc polygon, assuming only one contour (no holes)
Copyright: 	   ? 2002 Nicolas Ribot.
#include "postgres.h"
#include <math.h>
#include <float.h>
#include <string.h>
#include <stdio.h>
#include <errno.h>
#include "access/gist.h"
#include "access/itup.h"
#include "utils/elog.h"
#include "scot_gpc.h"
* performs the union of 2 polygons
* supports MULTIPOLYGON with only one polygon in it
* Returns null if input types are not polygons, or
* different SRIDS
* Returns a polygon or multipolygon according to result
PG_FUNCTION_INFO_V1(union_pg_pg);
Datum union_pg_pg(PG_FUNCTION_ARGS){
	GEOMETRY		    *geom1 =  (GEOMETRY *)  PG_DETOAST_DATUM(PG_GETARG_DATUM(0));
	GEOMETRY		    *geom2 =  (GEOMETRY *)  PG_DETOAST_DATUM(PG_GETARG_DATUM(1));
	GEOMETRY		    *result;
	// the conversion of geometry to POLYGON3D
	POLYGON3D           *poly1;
	POLYGON3D           *poly2;
	int32 			    *offset1;
	int32               *offset2;
	char                *o1;
	char                *o2;
elog(LOG,"\n--------------------------------------------------------------");
	// looks at the input geometries type
	if (geom1->type != POLYGONTYPE || geom2->type != POLYGONTYPE) {
		elog(ERROR,"Incompatible types for 2 geometries (expected POLYGON)");
		PG_RETURN_NULL();
	// should add support for multipolygon with 1 object in it
	// should provide a function to add 2 input geom into the result in case of
	// disjoint geometries.
	// creates the 2 polygons
	offset1 = (int32 *) ( ((char *) &(geom1->objType[0] ))+ sizeof(int32) * geom1->nobjs );
	offset2 = (int32 *) ( ((char *) &(geom2->objType[0] ))+ sizeof(int32) * geom2->nobjs );
	o1 = (char *) geom1 +offset1[0];
	o2 = (char *) geom2 +offset2[0];
	poly1 = (POLYGON3D *)o1;
	poly2 = (POLYGON3D *)o2;
	// are geometries equals ?
	if (is_same_polygon(poly1, poly2)) {
		// A U B = A or B if A=B
elog(LOG, "union_pg_pg: same input polygons, returning first one");
		PG_RETURN_POINTER(geom1);
elog(LOG,"union_pg_pg: input polygon 1: %s", geometry_to_text(geom1));
elog(LOG,"union_pg_pg: input polygon 2: %s", geometry_to_text(geom2));
	result = scot_gpc_clipping(poly1, poly2, GPC_UNION, geom1->SRID);
	if (result == NULL) {
		// empty result set, not an error.
		PG_RETURN_NULL();
	} else {
		result->SRID = geom1->SRID;
		PG_RETURN_POINTER(result);
* performs the intersection of 2 polygons
* different SRIDS
PG_FUNCTION_INFO_V1(intersection_pg_pg);
Datum intersection_pg_pg(PG_FUNCTION_ARGS){
	GEOMETRY		    *result;
	POLYGON3D           *poly1;
	POLYGON3D           *poly2;
	int32 			    *offset1;
	int32               *offset2;
	char                *o1;
	char                *o2;
		PG_RETURN_NULL();
	if (geom1->SRID != geom2->SRID)	{
		elog(ERROR,"Operation on two GEOMETRIES with different SRIDs");
		PG_RETURN_NULL();
	// the basic optimizations:
	// are their bbox disjoints ?
	if (!box3d_ov(&(geom1->bvol), &(geom2->bvol))) {
elog(LOG,"Geometries bbox disjoint");
		PG_RETURN_NULL();
elog(LOG, "same input polygons, returning first one");
elog(LOG,"intersection_pg_pg: input polygon 1: %s", geometry_to_text(geom1));
elog(LOG,"intersection_pg_pg: input polygon 2: %s", geometry_to_text(geom2));
	result = scot_gpc_clipping(poly1, poly2, GPC_INT, geom1->SRID);
		PG_RETURN_NULL();
	} else {
* performs the difference of polygon1 - polygon2
* (parameters order)
* different SRIDS
PG_FUNCTION_INFO_V1(difference_pg_pg);
Datum difference_pg_pg(PG_FUNCTION_ARGS) {
	GEOMETRY		    *result;
	POLYGON3D           *poly1;
	POLYGON3D           *poly2;
	int32 			    *offset1;
	int32               *offset2;
	char                *o1;
	char                *o2;
		PG_RETURN_NULL();
		PG_RETURN_NULL();
		// result is first geom: A-B = A
elog(LOG,"difference_pg_pg: Geometries bbox disjoint");
elog(LOG, "difference_pg_pg: same input polygons, returning first one");
		PG_RETURN_NULL();
elog(LOG,"difference_pg_pg: input polygon 1: %s", geometry_to_text(geom1));
elog(LOG,"difference_pg_pg: input polygon 2: %s", geometry_to_text(geom2));
	result = scot_gpc_clipping(poly1, poly2, GPC_DIFF, geom1->SRID);
		PG_RETURN_NULL();
	} else {
 * performs the symmetric difference of polygon1 - polygon2
 * different SRIDS
PG_FUNCTION_INFO_V1(sym_difference_pg_pg);
Datum sym_difference_pg_pg(PG_FUNCTION_ARGS) {
	GEOMETRY		    *result;
	POLYGON3D           *poly1;
	POLYGON3D           *poly2;
	int32 			    *offset1;
	int32               *offset2;
	char                *o1;
	char                *o2;
		elog(ERROR,"sym_difference_pg_pg: Incompatible types for 2 geometries (expected POLYGON)");
		PG_RETURN_NULL();
		elog(ERROR,"sym_difference_pg_pg: Operation on two GEOMETRIES with different SRIDs");
		PG_RETURN_NULL();
elog(LOG, "sym_difference_pg_pg: same input polygons, returning first one");
elog(LOG,"sym_difference_pg_pg: input polygon 1: %s", geometry_to_text(geom1));
elog(LOG,"sym_difference_pg_pg: input polygon 2: %s", geometry_to_text(geom2));
	result = scot_gpc_clipping(poly1, poly2, GPC_XOR, geom1->SRID);
		PG_RETURN_NULL();
	} else {
 * Performs the gpc clipping operation on the 2 given polygons
 * and returns a pointer to resulting geometry (POLYGON or MULTIPOLYGON)
GEOMETRY * scot_gpc_clipping(POLYGON3D *ppoly1, POLYGON3D *ppoly2, gpc_op operation, int SRID) {
	// the gpc object on which real computation will be done
	gpc_polygon gpcsubject, gpcclip, gpcresult;
	// creates gpc polygon from postgis geometry:
	POLYGON3D_to_gpc(ppoly1, &gpcsubject);
	POLYGON3D_to_gpc(ppoly2, &gpcclip);
	// perform the clipping operation (union geom1-geom2 for test)
	gpc_polygon_clip(operation, &gpcsubject, &gpcclip, &gpcresult);
	// converts and returns the result
	return ( gpc_to_GEOMETRY(&gpcresult, SRID) );
 * Converts the given POLYGON3D object into a gpc polygon
void POLYGON3D_to_gpc(POLYGON3D *ppoly, gpc_polygon *p) {
	int c, v;
	// is the current polygon ring a hole ?
	int isHole;
	// the position of the current point in the array of points for the poly
	int point_offset;
	// the array of points for each ring
	POINT3D	*pts;
	// First ring is always exterior for OpenGIS polygon
	isHole = 0;
	// copy the number of rings of the input polygon
	p->num_contours = ppoly->nrings;
#ifdef _DEBUG_
//elog(LOG,"POLYGON3D_to_gpc: num rings to convert: %d", ppoly->nrings);
#endif
	// allocates rings
	MALLOC(p->hole,    p->num_contours * sizeof(int),             "hole flag array creation");
	MALLOC(p->contour, p->num_contours * sizeof(gpc_vertex_list), "contour creation");
	// gets the array of points for all the rings forming the polygon:
	pts = (POINT3D *) ( (char *)&(ppoly->npoints[ppoly->nrings] )  );
	pts = (POINT3D *) MAXALIGN(pts);
	point_offset = 0;
	// loop for each ring, num_countours is the number of rings in ppoly
	for (c= 0; c < p->num_contours; c++) {
		// num vertices for this ring: 1 less than postgis polygon
		p->contour[c].num_vertices = ppoly->npoints[c] - 1;
		// set hole feature of this poly
		p->hole[c] = isHole;
		if (c == 0) {
			// now first ring is treated, all other rings are holes
			isHole = 1;
		// allocates vertex for this ring
		MALLOC(p->contour[c].vertex, p->contour[c].num_vertices * sizeof(gpc_vertex), "vertex creation");
		// copies each vertex coordinates from opengis poly to gpc poly
		for (v= 0; v < p->contour[c].num_vertices; v++) {
			p->contour[c].vertex[v].x = pts[v+point_offset].x;
			p->contour[c].vertex[v].y = pts[v+point_offset].y;
//elog(LOG,"POLYGON3D_to_gpc: vertex read from ring %d: %f %f", c, p->contour[c].vertex[v].x, p->contour[c].vertex[v].y);
//elog(LOG,"POLYGON3D_to_gpc: read %d vertices for ring %d", v, c);
		// increments current ring offset: must go forward in the array of
		// points to the next ring's first point,
		// be careful that postgis polygons contain 1 more vertex than gpc polygon do
		// point_offset is here the position inside pts array. The last opengis polygon
		// vertex is discarded this way
		point_offset += ppoly->npoints[c];
elog(LOG,"POLYGON3D_to_gpc: gpc_poly: %s", gpc_polygon_to_text(p));
 * Converts the given gpc polygon into a GEOMETRY.
 * As gpc can represent a multipolygon, we cannot return
 * a polygon3D object, to stay symmetric with POLYGON3D_to_gpc function.
 * Should provide an efficient way to dynamically allocates memory for
 * resulting polygon(s).
 * CAUTION: For the moment, max number of resulting polygons is limited to 100,
 * max number of holes per polygon is limited to 10. (+ 1 ext)
 * MUST change that for a dynamic allocation mechanism.
#define MAX_HOLES 10
#define MAX_RINGS 100
GEOMETRY* gpc_to_GEOMETRY(gpc_polygon *p, int SRID) {
	GEOMETRY *result;
	// the bbox of the result.
	BOX3D    *the_bbox;
	POLYGON3D *tmp_obj;
//	POLYGON3D *ppoly;
	int       tmp_obj_size=0;
	// some loop counters
	int 			c, v;
	// number of resulting postgis polygons (exterior contours in the given gpc poly);
	int num_polygons = 0;
	// the array of polygons contained in the gpc polygon
	// each line is an array of rings forming a postgis polygon.
	// All values in this bi-d array is an index of p->contour[];
	// The indices are sorted so that all holes belong to the right exterior.
	// the postgis point_in_polygon function is used to determine that
	// First entry in a line is the polygon's exterior. Other are holes
	int polygons [MAX_RINGS] [MAX_HOLES+1];
	// the array of polygon's size, ie the number of rings forming each polygon.
	// this array is // to polygons
	int num_rings[MAX_RINGS];
	// the number of rings for the current polygon
	int tmp_num_rings = 0;
	// test input gpc emptiness
	if (p->num_contours == 0) {
elog(LOG, "********gpc result polygon is empty****************");
		return NULL;
//elog(LOG,"gpc_to_GEOMETRY: num countours2: %d", p->num_contours);
elog(LOG,"gpc_to_GEOMETRY: gpc_poly: %s", gpc_polygon_to_text(p));
	// construct the polygons array according to p->contours parameters:
	// is it a hole or not, if so, which exterior does it belong to ?
	for (c = 0; c < p->num_contours; c++) {
		if (p->hole[c] == 0) {
//elog(LOG,"gpc_to_GEOMETRY: find ext at %d", c);
			// this is a new polygon:
			num_polygons++;
			// this is also a new ring for this current polygon
			tmp_num_rings++;
			// stores the index of this ring into our array
			polygons[num_polygons-1][tmp_num_rings-1] = c;
			// reloop for each interior, to see if it belongs to the polygon
			for (v = 0; v < p->num_contours; v++) {
				if (p->hole[v] == 1) {
//elog(LOG,"gpc_to_GEOMETRY: find int at %d", v);
					// this is a hole, look if it belongs to the current exterior
					if (gpc_hole_in_gpc_contour(p, c, v)) {
//elog(LOG,"gpc_to_GEOMETRY: Current contour (%d) is inside Exterior %d",v, c);
						// a new ring for the current polygon
						tmp_num_rings++;
						// stores its index into our array
						// contour at index v is inside ppoly: a new ring
						polygons[num_polygons-1][tmp_num_rings-1] = v;
			} // end for interiors
			// all interiors for this current ring are treaded: store their count:
			num_rings[num_polygons-1] = tmp_num_rings;
			// can pass to next exterior, with 0 rings
			tmp_num_rings = 0;
	} // end for exteriors
elog(LOG,"gpc_to_GEOMETRY: after ordering: found %d polys", num_polygons);
elog(LOG,"gpc_to_GEOMETRY: final matrix:");
for (c = 0; c < num_polygons; c++) {
	elog(LOG,"polygon %d: ", c);
	for (v = 0; v < num_rings[c]; v++) {
		elog(LOG,"\tring %d", polygons[c][v]);
	//construct a geometry with first polygon,
	tmp_obj = gpc_to_POLYGON3D(p, polygons[0], num_rings[0], SRID, &tmp_obj_size);
	result = make_oneobj_geometry(tmp_obj_size,
	                              (char *)tmp_obj,
	                              POLYGONTYPE,
	                              FALSE,
	                              SRID,
	                              1.0,
	                              0.0,
	                              0.0
//elog(LOG,"gpc_to_GEOMETRY: first resulting polygon built: %s", geometry_to_text(result));
	// adds all other polygons into it
	for (c = 1; c < num_polygons; c++) {
		tmp_obj = gpc_to_POLYGON3D(p, polygons[c], num_rings[c], SRID, &tmp_obj_size);
		result = add_to_geometry(result, tmp_obj_size, (char *)tmp_obj, POLYGONTYPE);
	//computes the bbox
	the_bbox = bbox_of_geometry(result);
	if (the_bbox != NULL) {
		memcpy( &result->bvol, the_bbox, sizeof(BOX3D) );
		pfree(the_bbox);
elog(LOG,"gpc_to_GEOMETRY: resulting polygon %d built: %s", c, geometry_to_text(result));
	return result;
Builds a geometry from the given gpc_polygon,
rings is the array of indices into p->contour[] forming the polygon
MUST control the contour orientation: if it is cw or ccw.
Have to add vertices in good order to opengis ccw polygon orientation
This code is more or less a copy of the one in gpc_to_POLYGON3D:
Should change that to merge codes.
POLYGON3D * gpc_to_POLYGON3D(gpc_polygon *p, int *rings, int num_rings, int SRID, int *ppoly_size) {
	POLYGON3D *ppoly;
	// The array of points: total number of points for all rings
	POINT3D   *pts;
	int       c, v, ci;
	int  	  num_vertices = 0;
	// array of points per ring
	int		  *pts_per_ring;
	// the total number of points, used to set pts position correctly
	int       point_offset = 0;
	// first, creates a new polygon from scratch.
	pts_per_ring = malloc(num_rings * (sizeof(int)));
	// loop through all given rings to get geometry's num points
	for (c = 0; c < num_rings; c++) {
		// contour's index
		ci = rings[c];
		num_vertices += p->contour[ci].num_vertices + 1; /* reserve an extra point */
		pts_per_ring[c] = p->contour[ci].num_vertices + 1;
	pts = malloc(num_vertices * sizeof(POINT3D));
	//loop through all contours to build the polygon
		// contour's index
		ci = rings[c];
//elog(LOG,"gpc_to_POLYGON3D: treating gpc contour %d", ci);
		// for each vertex in the current contour:
		// a contour has at least 3 vertices
		if (is_ccw(p->contour[ci].vertex[0].x,
		        p->contour[ci].vertex[0].y,
		        p->contour[ci].vertex[1].x,
			    p->contour[ci].vertex[1].y,
			    p->contour[ci].vertex[2].x,
			    p->contour[ci].vertex[2].y)) {
//elog(LOG,"gpc_to_POLYGON3D: ring: %d is ccw: add coordinates normally", c);
			// gpc contour is ccw, can add its vertices normally
			for (v = 0; v < p->contour[ci].num_vertices; v++) {
				set_point( &pts[v + point_offset],
				           p->contour[ci].vertex[v].x,
				           p->contour[ci].vertex[v].y, 0.0);
			// adds the first point at the end to close the postgis ring
			set_point( &pts[v+point_offset],
			           0.0);
		} else {
//elog(LOG,"gpc_to_POLYGON3D: ring: %d is cw: add coordinates in reverse order", c);
			// gpc contour is cw, must loop back to construct a postgis poly
			// with a good orientation
			for (v = p->contour[ci].num_vertices-1; v >= 0 ; v--) {
				set_point( &pts[(p->contour[ci].num_vertices-v-1)+point_offset],
			set_point( &pts[p->contour[ci].num_vertices+point_offset],
			           p->contour[ci].vertex[p->contour[ci].num_vertices-1].x,
			           p->contour[ci].vertex[p->contour[ci].num_vertices-1].y,
			           0.0);
		// increments the point offset= total number of vertices since here
		point_offset += p->contour[ci].num_vertices + 1;
	} // end loop for all contours
	//make the polygon
elog(LOG,"gpc_to_POLYGON3D: making final polygon for %d rings, %d vertices",num_rings, num_vertices);
	ppoly = make_polygon(num_rings, pts_per_ring, pts, num_vertices, ppoly_size);
	return ppoly;
Returns geom1 in which geom2 was added.
GEOMETRY* add_geometry(GEOMETRY *geom1, GEOMETRY *geom2) {
	BOX3D    *the_bbox;
	geom1 = make_oneobj_geometry(tmp_obj_size,
	                              (char *)tmp_obj,
	                              POLYGONTYPE,
	                              FALSE,
	                              SRID,
	                              1.0,
	                              0.0,
	                              0.0
 * Returns true if x0y0, x1y1, x2y2 is ccw (trigo orientation)
 * computes the cross product of the 3 points
bool is_ccw(double x0, double y0, double x1, double y1, double x2, double y2) {
	return (x0*y1 + x2*y0 + x1*y2 - x2*y1 - x0*y2 - x1*y0) >= 0;
 * Returns true if first point of given gpc polygon contour lies
 * in given polygon3d.
 * i is the contour index into c.
 * as a opengis polygon hole may touch the exterior, performs the test
 * on 2 consecutive points in case of negative result.
 * (2 consecutive points cannot lie on the exterior)
bool contour_in_POLYGON3D(POLYGON3D *ppoly, gpc_polygon *p, int i) {
	POINT3D pt;
	pt.x = p->contour[i].vertex[0].x;
	pt.y = p->contour[i].vertex[0].y;
	pt.z = 0.0;
	if (point_in_poly(&pt, ppoly)) {
		return TRUE;
	// test with next point
	pt.x = p->contour[i].vertex[1].x;
	pt.y = p->contour[i].vertex[1].y;
	pt.z = 0.0;
	return point_in_poly(&pt, ppoly);
 * Return true if the given gpc_hole is inside the given gpc_contour:
 * p the gpc_polygon containing all holes and contour.
 * c, the index of exterior contour to search in, in the p->contour array.
 * v, the index of interior contour to search for, in the p->contour array.
 * Assuming that 2 consecutive vertices cannot be on the exterior, searches
 * for the 2 first interior vertices to see if it is inside.
 * this assumption has to be confirmed by examples.
bool gpc_hole_in_gpc_contour(gpc_polygon *p, int c, int v) {
#ifdef _DEBUG_
//elog(ERROR, "gpc_hole_in_gpc_contour");
#endif
	if (point_in_gpc_poly(p->contour[v].vertex,
	                      p->contour[c].num_vertices) == 1) {
		return true;
	return (point_in_gpc_poly(p->contour[v].vertex,
	                          p->contour[c].num_vertices) == 1);
// copied from postgis_fn.c:
// adapted to work with gpc types:
// cn_PnPoly(): crossing number test for a point in a polygon
//      input:   P = a vertex,
//               V[] = vertex points of a contour V[n] with V[n]!=V[0]
//      returns: 0 = outside, 1 = inside
//	Our polygons DOES NOT have first and last point the same:
//  Must take first point when reaching the end of the ring
int point_in_gpc_poly( gpc_vertex *P, gpc_vertex *V, int n ) {
    int    cn = 0;    // the crossing number counter
 	int    i;
	double vt;
	gpc_vertex last_point;
//elog(ERROR, "point_in_gpc_poly: testing point [%g %g]", P->x, P->y);
    // loop through all edges of the polygon
    for (i=0; i< n; i++) {
		// compute last point:
		if ( i == n-1 ) {
			// last point is first one, last segment is treated
			last_point = V[0];
		} else {
			last_point = V[i+1];
       	if (((V[i].y <= P->y) && (last_point.y > P->y)) // an upward crossing
       		 || ((V[i].y > P->y) && (last_point.y <= P->y))) { // a downward crossing
       	   	vt = (double)(P->y - V[i].y) / (last_point.y - V[i].y);
         	if (P->x < V[i].x + vt * (last_point.x - V[i].x)) {
         		// P.x <intersect
           	    ++cn;   // a valid crossing of y=P.y right of P.x
    return (cn&1);    // 0 if even (out), and 1 if odd (in)
To debug gpc_polygon on screen.
  From postgis_inout.c:
#define SHOW_DIGS_DOUBLE 15
#define MAX_DIGS_DOUBLE (SHOW_DIGS_DOUBLE + 4 + 1 + 2 +1)
char* gpc_polygon_to_text(gpc_polygon *p) {
	int size = 12;// "gpc_polygon" + null
	char *res;
	int c = 0, v;
	char temp[MAX_DIGS_DOUBLE*2 + 4];
	res = (char *) palloc(size);
	strcpy(res, "gpc_polygon");
	for (c=0; c < p->num_contours; c++) {
		// reallocates for this new contour:
		size += (p->contour[c].num_vertices * (2*MAX_DIGS_DOUBLE +1+1)) + 3 + 2; //(int,x y,x y)
		res = (char *)repalloc(res, size);
		if (p->hole[c]) {
			// interior
			strcat(res, "(int,");
		} else {
			strcat(res, "(ext,");
		for (v=0; v < p->contour[c].num_vertices; v++) {
			sprintf(temp, "%.15g %.15g", p->contour[c].vertex[v].x, p->contour[c].vertex[v].y);
			strcat(res, temp);
			strcat(res, ",");
		// closes this contour
		strcat(res, ")");
	return res;
 tests
  very first gpc operation on 2 geometries
  Works only on 2 real POLYGON object,
PG_FUNCTION_INFO_V1(test_geogpc);
Datum test_geogpc(PG_FUNCTION_ARGS) {
	GEOMETRY		    *result = (GEOMETRY *) palloc(sizeof(GEOMETRY) );
	POLYGON3D           *poly1;
	POLYGON3D           *poly2;
	POLYGON3D           *poly_res;
	int32 			    *offset1;
	int32               *offset2;
	int 				poly_res_size;
	char                *o1;
	char                *o2;
	// for debug only
	/* gpc types */
		PG_RETURN_NULL();
#ifdef _DEBUG_
elog(LOG,"geom type is polygon ");
#endif
		PG_RETURN_NULL();
#ifdef _DEBUG_
elog(LOG,"SRID's are equals ");
#endif
	// creates the 2 polygons and 2 gpc polygons on which operations will be done
	// creates gpc polygon from postgis polygons:
	scot_gpc_read_polygon(poly1, &gpcsubject);
	scot_gpc_read_polygon(poly2, &gpcclip);
	gpc_polygon_clip(GPC_UNION, &gpcsubject, &gpcclip, &gpcresult);
	//Convert result to opengis polygon:
	poly_res = scot_gpc_write_polygon(&gpcresult, &poly_res_size);
	result = make_oneobj_geometry(poly_res_size,
	                              (char *)poly_res,
	                              POLYGONTYPE,
	                              FALSE,
	                              geom1->SRID,
	                              geom1->scale,
	                              geom1->offsetX,
	                              geom1->offsetY
#ifdef _DEBUG_
elog(LOG,"test_geogpc: WKT representation of result: %s\n", geometry_to_text(result));
#endif
	// free memory for gpc polygons.
	gpc_free_polygon(&gpcsubject);
	gpc_free_polygon(&gpcclip);
	gpc_free_polygon(&gpcresult);
	// free memory for postgis polygons ?
	PG_FREE_IF_COPY(geom1, 0);
	PG_FREE_IF_COPY(geom2, 1);
add-on to GPC to allow the construction of a polygon from an array of coordinates instead of file
method should allow the construction of a GPC polygon from a postgis POLYGON or MULTIPOLYGON
// original method from gpc.c
void gpc_read_polygon(FILE *fp, int read_hole_flags, gpc_polygon *p) {
  int c, v;
  fscanf(fp, "%d", &(p->num_contours));
    fscanf(fp, "%d", &(p->contour[c].num_vertices));
    if (read_hole_flags)
      fscanf(fp, "%d", &(p->hole[c]));
    else
      p->hole[c]= FALSE;
      fscanf(fp, "%lf %lf", &(p->contour[c].vertex[v].x),
                            &(p->contour[c].vertex[v].y));
No control is made on the input polygon3d geometry. Use this function with caution
Convention: when referening to gpc polygons, contour is the ring
for opengis poly, ring is a contour, first one is exterior, all other are holes.
CAUTION: postgis polygons have their last ring point = first one, must deal with this
when building gpc polygons.
void scot_gpc_read_polygon(POLYGON3D *ppoly, gpc_polygon *p) {
	int c, v;
	int isHole;
	int point_offset;
	POINT3D	*pts;
	isHole = 0;
#ifdef _DEBUG_
elog(LOG,"gpc_read_polygon: num rings to convert: %d", ppoly->nrings);
#endif
	// allocates rings
	point_offset = 0;
		// num vertices for this ring: 1 less thant postgis polygon
		if (c == 0) {
			isHole = 1;
			p->contour[c].vertex[v].x = pts[v].x;
			p->contour[c].vertex[v].y = pts[v].y;
#ifdef _DEBUG_
elog(LOG,"gpc_read_polygon: vertex read from ring %d: %f %f", c, p->contour[c].vertex[v].x, p->contour[c].vertex[v].y);
#endif
#ifdef _DEBUG_
elog(LOG,"gpc_read_polygon: read %d vertices for ring %d", v, c);
#endif
		//increments current ring offset: must go forward in the array of points to the next ring's first point,
Write function, from GPC code
void gpc_write_polygon(FILE *fp, int write_hole_flags, gpc_polygon *p)
  int c, v;
  fprintf(fp, "%d\n", p->num_contours);
    fprintf(fp, "%d\n", p->contour[c].num_vertices);
    if (write_hole_flags)
      fprintf(fp, "%d\n", p->hole[c]);
      fprintf(fp, "% .*lf % .*lf\n",
              DBL_DIG, p->contour[c].vertex[v].x,
              DBL_DIG, p->contour[c].vertex[v].y);
Writes an existing gpc polygon into a newly created postgis polygon
No control is made on the input gpc polygon geometry. Use this function with caution
caution: the number of vertices in each gpc polygon is 1 less than the number in
postgis polygon, as OpenGIS says a ring must have its last point=first point.
Force this point in this code.
POLYGON3D * scot_gpc_write_polygon(gpc_polygon *p, int *ppoly_size) {
	int 			c, v;
	POINT3D			*pts;
	POLYGON3D       *ppoly; /*the result*/
	int				*pts_per_ring;
#ifdef _DEBUG_
elog(LOG,"gpc_write_polygon: num rings to write: %d", p->num_contours);
#endif
	pts_per_ring = malloc(p->num_contours * sizeof(int));
		num_vertices += p->contour[c].num_vertices + 1; /* reserve an extra point */
		pts_per_ring[c] = p->contour[c].num_vertices + 1;
	//loop for all contours to take their vertices
	// no holes to take into account as postgis will treat them correctly
#ifdef _DEBUG_
elog(LOG,"gpc_write_polygon: start of the loop: %d", p->contour[c].num_vertices);
#endif
		for (v = p->contour[c].num_vertices-1; v >= 0 ; v--) {
			set_point( &pts[c+(p->contour[c].num_vertices-v-1)], p->contour[c].vertex[v].x, p->contour[c].vertex[v].y, 0.0);
#ifdef _DEBUG_
elog(LOG,"gpc_write_polygon: coord (%d) written: %f %f",v,  p->contour[c].vertex[v].x, p->contour[c].vertex[v].y);
#endif
		set_point( &pts[c + p->contour[c].num_vertices], p->contour[c].vertex[p->contour[c].num_vertices-1].x, p->contour[c].vertex[p->contour[c].num_vertices-1].y, 0.0);
#ifdef _DEBUG_
elog(LOG,"gpc_write_polygon: LAST coord written: %f %f", p->contour[c].vertex[p->contour[c].num_vertices-1].x, p->contour[c].vertex[p->contour[c].num_vertices-1].y);
#endif
#ifdef _DEBUG_
elog(LOG,"gpc_write_polygon: written %d vertices for ring: %d", v+1, c);
#endif
	//make the polygon
	ppoly = make_polygon(p->num_contours, pts_per_ring, pts, num_vertices, ppoly_size);
	return ppoly;
/* working code backup
		for (v = 0; v < p->contour[c].num_vertices; v++) {
			set_point( &pts[c+v], p->contour[c].vertex[v].x, p->contour[c].vertex[v].y, 0.0);
		set_point( &pts[c+v+1], p->contour[c].vertex[0].x, p->contour[c].vertex[0].y, 0.0);
