[postgis-users] Re: C question, PG_RETURN_POINTER: GPC integration
Cedric BERNIER cedric.bernier at thales-is.com
Tue Apr 30 08:13:58 PDT 2002
Bonjour Nicolas,
J'ai perdu le fil de la conversation, pourrais tu me rappeler ce que font tes 2 fonctions C ?
qu'est ce que le gpc ?
Merci
Cedric
Nicolas Ribot a écrit :
> Mr Ono,
> (and maybe other people interested)
> Here are the files (scot_gpc.c and scot_gpc.h).
> I tested the functions with very simple geometries.
> I join to the c files a sql file containing the dump of the postgis table
> (testgpc).
> >  Thank you very much, Mr. Ribot. I'd like to try some geometries using your
> > functions.
> >  Regards.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Project:   Generic Polygon Clipper
>            A new algorithm for calculating the difference, intersection,
>            exclusive-or or union of arbitrary polygon sets.
> File:      gpc.h
> Author:    Alan Murta (email: gpc at cs.man.ac.uk)
> Version:   2.31
> Date:      4th June 1999
> Copyright: (C) 1997-1999, Advanced Interfaces Group,
>            University of Manchester.
>            This software is free for non-commercial use. It may be copied,
>            modified, and redistributed provided that this copyright notice
>            is preserved on all copies. The intellectual property rights of
>            the algorithms used reside with the University of Manchester
>            Advanced Interfaces Group.
>            You may not use this software, in whole or in part, in support
>            of any commercial product without the express consent of the
>            author.
>            There is no warranty or other guarantee of fitness of this
>            software for any purpose. It is provided solely "as is".
> #ifndef __gpc_h
> #define __gpc_h
> #include <stdio.h>
>                                Constants
> /* Increase GPC_EPSILON to encourage merging of near coincident edges    */
> #define GPC_EPSILON (DBL_EPSILON)
> #define GPC_VERSION "2.31"
>                            Public Data Types
> typedef enum                        /* Set operation type                */
>   GPC_DIFF,                         /* Difference                        */
>   GPC_INT,                          /* Intersection                      */
>   GPC_XOR,                          /* Exclusive or                      */
>   GPC_UNION                         /* Union                             */
> } gpc_op;
> typedef struct                      /* Polygon vertex structure          */
>   double              x;            /* Vertex x component                */
>   double              y;            /* vertex y component                */
> } gpc_vertex;
> typedef struct                      /* Vertex list structure             */
>   int                 num_vertices; /* Number of vertices in list        */
>   gpc_vertex         *vertex;       /* Vertex array pointer              */
> } gpc_vertex_list;
> typedef struct                      /* Polygon set structure             */
>   int                 num_contours; /* Number of contours in polygon     */
>   int                *hole;         /* Hole / external contour flags     */
>   gpc_vertex_list    *contour;      /* Contour array pointer             */
> } gpc_polygon;
> typedef struct                      /* Tristrip set structure            */
>   int                 num_strips;   /* Number of tristrips               */
>   gpc_vertex_list    *strip;        /* Tristrip array pointer            */
> } gpc_tristrip;
>                        Public Function Prototypes
> void gpc_read_polygon        (FILE            *infile_ptr,
>                               int              read_hole_flags,
>                               gpc_polygon     *polygon);
> void gpc_write_polygon       (FILE            *outfile_ptr,
>                               int              write_hole_flags,
> void gpc_add_contour         (gpc_polygon     *polygon,
>                               gpc_vertex_list *contour,
>                               int              hole);
> void gpc_polygon_clip        (gpc_op           set_operation,
>                               gpc_polygon     *subject_polygon,
>                               gpc_polygon     *clip_polygon,
>                               gpc_polygon     *result_polygon);
> void gpc_tristrip_clip       (gpc_op           set_operation,
>                               gpc_tristrip    *result_tristrip);
> void gpc_polygon_to_tristrip (gpc_polygon     *polygon,
>                               gpc_tristrip    *tristrip);
> void gpc_free_polygon        (gpc_polygon     *polygon);
> void gpc_free_tristrip       (gpc_tristrip    *tristrip);
> #endif
>                            End of file: gpc.h
> File:      gpc.c
> Version:   2.31
> Date:      4th June 1999
>            author.
>                                 Includes
> #include "gpc.h"
> #include <stdlib.h>
> #include <float.h>
> #include <math.h>
>                                 Constants
> #ifndef TRUE
> #define FALSE              0
> #define TRUE               1
> #endif
> #define LEFT               0
> #define RIGHT              1
> #define ABOVE              0
> #define BELOW              1
> #define CLIP               0
> #define SUBJ               1
> #define INVERT_TRISTRIPS   FALSE
>                                  Macros
> #define EQ(a, b)           (fabs((a) - (b)) <= GPC_EPSILON)
> #define PREV_INDEX(i, n)   ((i - 1 + n) % n)
> #define NEXT_INDEX(i, n)   ((i + 1    ) % n)
> #define OPTIMAL(v, i, n)   ((v[PREV_INDEX(i, n)].y != v[i].y) || \
>                             (v[NEXT_INDEX(i, n)].y != v[i].y))
> #define FWD_MIN(v, i, n)   ((v[PREV_INDEX(i, n)].vertex.y >= v[i].vertex.y) \
>                          && (v[NEXT_INDEX(i, n)].vertex.y > v[i].vertex.y))
> #define NOT_FMAX(v, i, n)   (v[NEXT_INDEX(i, n)].vertex.y > v[i].vertex.y)
> #define REV_MIN(v, i, n)   ((v[PREV_INDEX(i, n)].vertex.y > v[i].vertex.y) \
>                          && (v[NEXT_INDEX(i, n)].vertex.y >= v[i].vertex.y))
> #define NOT_RMAX(v, i, n)   (v[PREV_INDEX(i, n)].vertex.y > v[i].vertex.y)
> #define VERTEX(e,p,s,x,y)  {add_vertex(&((e)->outp[(p)]->v[(s)]), x, y); \
>                             (e)->outp[(p)]->active++;}
> #define P_EDGE(d,e,p,i,j)  {(d)= (e); \
>                             do {(d)= (d)->prev;} while (!(d)->outp[(p)]); \
>                             (i)= (d)->bot.x + (d)->dx * ((j)-(d)->bot.y);}
> #define N_EDGE(d,e,p,i,j)  {(d)= (e); \
>                             do {(d)= (d)->next;} while (!(d)->outp[(p)]); \
> #define MALLOC(p, b, s)    {if ((b) > 0) { \
>                             p= malloc(b); if (!(p)) { \
>                             fprintf(stderr, "gpc malloc failure: %s\n", s); \
>                             exit(0);}} else p= NULL;}
> #define FREE(p)            {if (p) {free(p); (p)= NULL;}}
>                             Private Data Types
> typedef enum                        /* Edge intersection classes         */
>   NUL,                              /* Empty non-intersection            */
>   EMX,                              /* External maximum                  */
>   ELI,                              /* External left intermediate        */
>   TED,                              /* Top edge                          */
>   ERI,                              /* External right intermediate       */
>   RED,                              /* Right edge                        */
>   IMM,                              /* Internal maximum and minimum      */
>   IMN,                              /* Internal minimum                  */
>   EMN,                              /* External minimum                  */
>   EMM,                              /* External maximum and minimum      */
>   LED,                              /* Left edge                         */
>   ILI,                              /* Internal left intermediate        */
>   BED,                              /* Bottom edge                       */
>   IRI,                              /* Internal right intermediate       */
>   IMX,                              /* Internal maximum                  */
>   FUL                               /* Full non-intersection             */
> } vertex_type;
> typedef enum                        /* Horizontal edge states            */
>   NH,                               /* No horizontal edge                */
>   BH,                               /* Bottom horizontal edge            */
>   TH                                /* Top horizontal edge               */
> } h_state;
> typedef enum                        /* Edge bundle state                 */
>   UNBUNDLED,                        /* Isolated edge not within a bundle */
>   BUNDLE_HEAD,                      /* Bundle head node                  */
>   BUNDLE_TAIL                       /* Passive bundle tail node          */
> } bundle_state;
> typedef struct v_shape              /* Internal vertex list datatype     */
>   double              x;            /* X coordinate component            */
>   double              y;            /* Y coordinate component            */
>   struct v_shape     *next;         /* Pointer to next vertex in list    */
> } vertex_node;
> typedef struct p_shape              /* Internal contour / tristrip type  */
>   int                 active;       /* Active flag / vertex count        */
>   int                 hole;         /* Hole / external contour flag      */
>   vertex_node        *v[2];         /* Left and right vertex list ptrs   */
>   struct p_shape     *next;         /* Pointer to next polygon contour   */
>   struct p_shape     *proxy;        /* Pointer to actual structure used  */
> } polygon_node;
> typedef struct edge_shape
>   gpc_vertex          vertex;       /* Piggy-backed contour vertex data  */
>   gpc_vertex          bot;          /* Edge lower (x, y) coordinate      */
>   gpc_vertex          top;          /* Edge upper (x, y) coordinate      */
>   double              xb;           /* Scanbeam bottom x coordinate      */
>   double              xt;           /* Scanbeam top x coordinate         */
>   double              dx;           /* Change in x for a unit y increase */
>   int                 type;         /* Clip / subject edge flag          */
>   int                 bundle[2][2]; /* Bundle edge flags                 */
>   int                 bside[2];     /* Bundle left / right indicators    */
>   bundle_state        bstate[2];    /* Edge bundle state                 */
>   polygon_node       *outp[2];      /* Output polygon / tristrip pointer */
>   struct edge_shape  *prev;         /* Previous edge in the AET          */
>   struct edge_shape  *next;         /* Next edge in the AET              */
>   struct edge_shape  *pred;         /* Edge connected at the lower end   */
>   struct edge_shape  *succ;         /* Edge connected at the upper end   */
>   struct edge_shape  *next_bound;   /* Pointer to next bound in LMT      */
> } edge_node;
> typedef struct lmt_shape            /* Local minima table                */
>   double              y;            /* Y coordinate at local minimum     */
>   edge_node          *first_bound;  /* Pointer to bound list             */
>   struct lmt_shape   *next;         /* Pointer to next local minimum     */
> } lmt_node;
> typedef struct sbt_t_shape          /* Scanbeam tree                     */
>   double              y;            /* Scanbeam node y value             */
>   struct sbt_t_shape *less;         /* Pointer to nodes with lower y     */
>   struct sbt_t_shape *more;         /* Pointer to nodes with higher y    */
> } sb_tree;
> typedef struct it_shape             /* Intersection table                */
>   edge_node          *ie[2];        /* Intersecting edge (bundle) pair   */
>   gpc_vertex          point;        /* Point of intersection             */
>   struct it_shape    *next;         /* The next intersection table node  */
> } it_node;
> typedef struct st_shape             /* Sorted edge table                 */
>   edge_node          *edge;         /* Pointer to AET edge               */
>   struct st_shape    *prev;         /* Previous edge in sorted list      */
> } st_node;
> typedef struct bbox_shape           /* Contour axis-aligned bounding box */
>   double             xmin;          /* Minimum x coordinate              */
>   double             ymin;          /* Minimum y coordinate              */
>   double             xmax;          /* Maximum x coordinate              */
>   double             ymax;          /* Maximum y coordinate              */
> } bbox;
>                                Global Data
> /* Horizontal edge state transitions within scanbeam boundary */
> const h_state next_h_state[3][6]=
>   /*        ABOVE     BELOW     CROSS */
>   /*        L   R     L   R     L   R */
>   /* NH */ {BH, TH,   TH, BH,   NH, NH},
>   /* BH */ {NH, NH,   NH, NH,   TH, TH},
>   /* TH */ {NH, NH,   NH, NH,   BH, BH}
>                              Private Functions
> static void reset_it(it_node **it)
>   it_node *itn;
>   while (*it)
>     itn= (*it)->next;
>     FREE(*it);
>     *it= itn;
> static void reset_lmt(lmt_node **lmt)
>   lmt_node *lmtn;
>   while (*lmt)
>     lmtn= (*lmt)->next;
>     FREE(*lmt);
>     *lmt= lmtn;
> static void insert_bound(edge_node **b, edge_node *e)
>   edge_node *existing_bound;
>   if (!*b)
>     /* Link node e to the tail of the list */
>     *b= e;
>   else
>     /* Do primary sort on the x field */
>     if (e[0].bot.x < (*b)[0].bot.x)
>       /* Insert a new node mid-list */
>       existing_bound= *b;
>       *b= e;
>       (*b)->next_bound= existing_bound;
>     else
>       if (e[0].bot.x == (*b)[0].bot.x)
>         /* Do secondary sort on the dx field */
>         if (e[0].dx < (*b)[0].dx)
>           existing_bound= *b;
>           *b= e;
>         else
>           /* Head further down the list */
>           insert_bound(&((*b)->next_bound), e);
>       else
> static edge_node **bound_list(lmt_node **lmt, double y)
>   lmt_node *existing_node;
>   if (!*lmt)
>     /* Add node onto the tail end of the LMT */
>     MALLOC(*lmt, sizeof(lmt_node), "LMT insertion");
>     (*lmt)->y= y;
>     (*lmt)->first_bound= NULL;
>     (*lmt)->next= NULL;
>     return &((*lmt)->first_bound);
>   else
>     if (y < (*lmt)->y)
>       /* Insert a new LMT node before the current node */
>       existing_node= *lmt;
>       (*lmt)->y= y;
>       (*lmt)->next= existing_node;
>     else
>       if (y > (*lmt)->y)
>         /* Head further up the LMT */
>         return bound_list(&((*lmt)->next), y);
>       else
>         /* Use this existing LMT node */
> static void add_to_sbtree(int *entries, sb_tree **sbtree, double y)
>   if (!*sbtree)
>     /* Add a new tree node here */
>     MALLOC(*sbtree, sizeof(sb_tree), "scanbeam tree insertion");
>     (*sbtree)->y= y;
>     (*sbtree)->less= NULL;
>     (*sbtree)->more= NULL;
>     (*entries)++;
>   else
>     if ((*sbtree)->y > y)
>     /* Head into the 'less' sub-tree */
>       add_to_sbtree(entries, &((*sbtree)->less), y);
>     else
>       if ((*sbtree)->y < y)
>         /* Head into the 'more' sub-tree */
>         add_to_sbtree(entries, &((*sbtree)->more), y);
> static void build_sbt(int *entries, double *sbt, sb_tree *sbtree)
>   if (sbtree->less)
>     build_sbt(entries, sbt, sbtree->less);
>   sbt[*entries]= sbtree->y;
>   (*entries)++;
>   if (sbtree->more)
>     build_sbt(entries, sbt, sbtree->more);
> static void free_sbtree(sb_tree **sbtree)
>   if (*sbtree)
>     free_sbtree(&((*sbtree)->less));
>     free_sbtree(&((*sbtree)->more));
>     FREE(*sbtree);
> static int count_optimal_vertices(gpc_vertex_list c)
>   int result= 0, i;
>   /* Ignore non-contributing contours */
>   if (c.num_vertices > 0)
>     for (i= 0; i < c.num_vertices; i++)
>       /* Ignore superfluous vertices embedded in horizontal edges */
>       if (OPTIMAL(c.vertex, i, c.num_vertices))
>         result++;
>   return result;
> static edge_node *build_lmt(lmt_node **lmt, sb_tree **sbtree,
>                             int *sbt_entries, gpc_polygon *p, int type,
>                             gpc_op op)
>   int          c, i, min, max, num_edges, v, num_vertices;
>   int          total_vertices= 0, e_index=0;
>   edge_node   *e, *edge_table;
>   for (c= 0; c < p->num_contours; c++)
>     total_vertices+= count_optimal_vertices(p->contour[c]);
>   /* Create the entire input polygon edge table in one go */
>   MALLOC(edge_table, total_vertices * sizeof(edge_node),
>          "edge table creation");
>     if (p->contour[c].num_vertices < 0)
>       /* Ignore the non-contributing contour and repair the vertex count */
>       p->contour[c].num_vertices= -p->contour[c].num_vertices;
>     else
>       /* Perform contour optimisation */
>       num_vertices= 0;
>       for (i= 0; i < p->contour[c].num_vertices; i++)
>         if (OPTIMAL(p->contour[c].vertex, i, p->contour[c].num_vertices))
>           edge_table[num_vertices].vertex.x= p->contour[c].vertex[i].x;
>           edge_table[num_vertices].vertex.y= p->contour[c].vertex[i].y;
>           /* Record vertex in the scanbeam table */
>           add_to_sbtree(sbt_entries, sbtree,
>                         edge_table[num_vertices].vertex.y);
>           num_vertices++;
>       /* Do the contour forward pass */
>       for (min= 0; min < num_vertices; min++)
>         /* If a forward local minimum... */
>         if (FWD_MIN(edge_table, min, num_vertices))
>           /* Search for the next local maximum... */
>           num_edges= 1;
>           max= NEXT_INDEX(min, num_vertices);
>           while (NOT_FMAX(edge_table, max, num_vertices))
>             num_edges++;
>             max= NEXT_INDEX(max, num_vertices);
>           /* Build the next edge list */
>           e= &edge_table[e_index];
>           e_index+= num_edges;
>           v= min;
>           e[0].bstate[BELOW]= UNBUNDLED;
>           e[0].bundle[BELOW][CLIP]= FALSE;
>           e[0].bundle[BELOW][SUBJ]= FALSE;
>           for (i= 0; i < num_edges; i++)
>             e[i].xb= edge_table[v].vertex.x;
>             e[i].bot.x= edge_table[v].vertex.x;
>             e[i].bot.y= edge_table[v].vertex.y;
>             v= NEXT_INDEX(v, num_vertices);
>             e[i].top.x= edge_table[v].vertex.x;
>             e[i].top.y= edge_table[v].vertex.y;
>             e[i].dx= (edge_table[v].vertex.x - e[i].bot.x) /
>                        (e[i].top.y - e[i].bot.y);
>             e[i].type= type;
>             e[i].outp[ABOVE]= NULL;
>             e[i].outp[BELOW]= NULL;
>             e[i].next= NULL;
>             e[i].prev= NULL;
>             e[i].succ= ((num_edges > 1) && (i < (num_edges - 1))) ?
>                        &(e[i + 1]) : NULL;
>             e[i].pred= ((num_edges > 1) && (i > 0)) ? &(e[i - 1]) : NULL;
>             e[i].next_bound= NULL;
>             e[i].bside[CLIP]= (op == GPC_DIFF) ? RIGHT : LEFT;
>             e[i].bside[SUBJ]= LEFT;
>           insert_bound(bound_list(lmt, edge_table[min].vertex.y), e);
>       /* Do the contour reverse pass */
>       /* If a reverse local minimum... */
>         if (REV_MIN(edge_table, min, num_vertices))
>           /* Search for the previous local maximum... */
>           num_edges= 1;
>           max= PREV_INDEX(min, num_vertices);
>           while (NOT_RMAX(edge_table, max, num_vertices))
>             num_edges++;
>             max= PREV_INDEX(max, num_vertices);
>           /* Build the previous edge list */
>           v= min;
>             v= PREV_INDEX(v, num_vertices);
>             e[i].type= type;
>             e[i].next= NULL;
>             e[i].prev= NULL;
>                        &(e[i + 1]) : NULL;
>   return edge_table;
> static void add_edge_to_aet(edge_node **aet, edge_node *edge, edge_node *prev)
>   if (!*aet)
>     /* Append edge onto the tail end of the AET */
>     *aet= edge;
>     edge->prev= prev;
>     edge->next= NULL;
>   else
>     /* Do primary sort on the xb field */
>     if (edge->xb < (*aet)->xb)
>       /* Insert edge here (before the AET edge) */
>       edge->prev= prev;
>       edge->next= *aet;
>       (*aet)->prev= edge;
>       *aet= edge;
>     else
>       if (edge->xb == (*aet)->xb)
>         if (edge->dx < (*aet)->dx)
>           edge->prev= prev;
>           edge->next= *aet;
>           (*aet)->prev= edge;
>           *aet= edge;
>         else
>           /* Head further into the AET */
>           add_edge_to_aet(&((*aet)->next), edge, *aet);
>       else
> static void add_intersection(it_node **it, edge_node *edge0, edge_node *edge1,
>                              double x, double y)
>   it_node *existing_node;
>   if (!*it)
>     /* Append a new node to the tail of the list */
>     MALLOC(*it, sizeof(it_node), "IT insertion");
>     (*it)->ie[0]= edge0;
>     (*it)->ie[1]= edge1;
>     (*it)->point.x= x;
>     (*it)->point.y= y;
>     (*it)->next= NULL;
>   else
>     if ((*it)->point.y > y)
>       existing_node= *it;
>       (*it)->point.x= x;
>       (*it)->point.y= y;
>       (*it)->next= existing_node;
>     else
>       add_intersection(&((*it)->next), edge0, edge1, x, y);
> static void add_st_edge(st_node **st, it_node **it, edge_node *edge,
>                         double dy)
>   st_node *existing_node;
>   double   den, r, x, y;
>   if (!*st)
>     /* Append edge onto the tail end of the ST */
>     MALLOC(*st, sizeof(st_node), "ST insertion");
>     (*st)->edge= edge;
>     (*st)->xb= edge->xb;
>     (*st)->xt= edge->xt;
>     (*st)->dx= edge->dx;
>     (*st)->prev= NULL;
>   else
>     den= ((*st)->xt - (*st)->xb) - (edge->xt - edge->xb);
>     /* If new edge and ST edge don't cross */
>     if ((edge->xt >= (*st)->xt) || (edge->dx == (*st)->dx) ||
>         (fabs(den) <= DBL_EPSILON))
>       /* No intersection - insert edge here (before the ST edge) */
>       existing_node= *st;
>       (*st)->edge= edge;
>       (*st)->prev= existing_node;
>     else
>       /* Compute intersection between new edge and ST edge */
>       r= (edge->xb - (*st)->xb) / den;
>       x= (*st)->xb + r * ((*st)->xt - (*st)->xb);
>       y= r * dy;
>       /* Insert the edge pointers and the intersection point in the IT */
>       add_intersection(it, (*st)->edge, edge, x, y);
>       /* Head further into the ST */
>       add_st_edge(&((*st)->prev), it, edge, dy);
> static void build_intersection_table(it_node **it, edge_node *aet, double dy)
>   st_node   *st, *stp;
>   edge_node *edge;
>   /* Build intersection table for the current scanbeam */
>   reset_it(it);
>   st= NULL;
>   /* Process each AET edge */
>   for (edge= aet; edge; edge= edge->next)
>     if ((edge->bstate[ABOVE] == BUNDLE_HEAD) ||
>          edge->bundle[ABOVE][CLIP] || edge->bundle[ABOVE][SUBJ])
>       add_st_edge(&st, it, edge, dy);
>   /* Free the sorted edge table */
>   while (st)
>     stp= st->prev;
>     FREE(st);
>     st= stp;
> static int count_contours(polygon_node *polygon)
>   int          nc, nv;
>   vertex_node *v, *nextv;
>   for (nc= 0; polygon; polygon= polygon->next)
>     if (polygon->active)
>       /* Count the vertices in the current contour */
>       nv= 0;
>       for (v= polygon->proxy->v[LEFT]; v; v= v->next)
>         nv++;
>       /* Record valid vertex counts in the active field */
>       if (nv > 2)
>         polygon->active= nv;
>         nc++;
>       else
>         /* Invalid contour: just free the heap */
>         for (v= polygon->proxy->v[LEFT]; v; v= nextv)
>           nextv= v->next;
>           FREE(v);
>         polygon->active= 0;
>   return nc;
> static void add_left(polygon_node *p, double x, double y)
>   vertex_node *nv;
>   /* Create a new vertex node and set its fields */
>   MALLOC(nv, sizeof(vertex_node), "vertex node creation");
>   nv->x= x;
>   nv->y= y;
>   /* Add vertex nv to the left end of the polygon's vertex list */
>   nv->next= p->proxy->v[LEFT];
>   /* Update proxy->[LEFT] to point to nv */
>   p->proxy->v[LEFT]= nv;
> static void merge_left(polygon_node *p, polygon_node *q, polygon_node *list)
>   polygon_node *target;
>   /* Label contour as a hole */
>   q->proxy->hole= TRUE;
>   if (p->proxy != q->proxy)
>     /* Assign p's vertex list to the left end of q's list */
>     p->proxy->v[RIGHT]->next= q->proxy->v[LEFT];
>     q->proxy->v[LEFT]= p->proxy->v[LEFT];
>     /* Redirect any p->proxy references to q->proxy */
>     for (target= p->proxy; list; list= list->next)
>       if (list->proxy == target)
>         list->active= FALSE;
>         list->proxy= q->proxy;
> static void add_right(polygon_node *p, double x, double y)
>   vertex_node *nv;
>   nv->x= x;
>   nv->y= y;
>   nv->next= NULL;
>   /* Add vertex nv to the right end of the polygon's vertex list */
>   p->proxy->v[RIGHT]->next= nv;
>   /* Update proxy->v[RIGHT] to point to nv */
>   p->proxy->v[RIGHT]= nv;
> static void merge_right(polygon_node *p, polygon_node *q, polygon_node *list)
>   /* Label contour as external */
>   q->proxy->hole= FALSE;
>     /* Assign p's vertex list to the right end of q's list */
>     q->proxy->v[RIGHT]->next= p->proxy->v[LEFT];
>     q->proxy->v[RIGHT]= p->proxy->v[RIGHT];
> static void add_local_min(polygon_node **p, edge_node *edge,
>                           double x, double y)
>   polygon_node *existing_min;
>   vertex_node  *nv;
>   existing_min= *p;
>   MALLOC(*p, sizeof(polygon_node), "polygon node creation");
>   nv->x= x;
>   nv->y= y;
>   nv->next= NULL;
>   /* Initialise proxy to point to p itself */
>   (*p)->proxy= (*p);
>   (*p)->active= TRUE;
>   (*p)->next= existing_min;
>   /* Make v[LEFT] and v[RIGHT] point to new vertex nv */
>   (*p)->v[LEFT]= nv;
>   (*p)->v[RIGHT]= nv;
>   /* Assign polygon p to the edge */
>   edge->outp[ABOVE]= *p;
> static int count_tristrips(polygon_node *tn)
>   int total;
>   for (total= 0; tn; tn= tn->next)
>     if (tn->active > 2)
>       total++;
>   return total;
> static void add_vertex(vertex_node **t, double x, double y)
>   if (!(*t))
>     MALLOC(*t, sizeof(vertex_node), "tristrip vertex creation");
>     (*t)->x= x;
>     (*t)->y= y;
>     (*t)->next= NULL;
>   else
>     add_vertex(&((*t)->next), x, y);
> static void new_tristrip(polygon_node **tn, edge_node *edge,
>                          double x, double y)
>   if (!(*tn))
>     MALLOC(*tn, sizeof(polygon_node), "tristrip node creation");
>     (*tn)->next= NULL;
>     (*tn)->v[LEFT]= NULL;
>     (*tn)->v[RIGHT]= NULL;
>     (*tn)->active= 1;
>     add_vertex(&((*tn)->v[LEFT]), x, y);
>     edge->outp[ABOVE]= *tn;
>   else
>     new_tristrip(&((*tn)->next), edge, x, y);
> static bbox *create_contour_bboxes(gpc_polygon *p)
>   bbox *box;
>   int   c, v;
>   MALLOC(box, p->num_contours * sizeof(bbox), "Bounding box creation");
>   /* Construct contour bounding boxes */
>     /* Initialise bounding box extent */
>     box[c].xmin= DBL_MAX;
>     box[c].ymin= DBL_MAX;
>     box[c].xmax= -DBL_MAX;
>     box[c].ymax= -DBL_MAX;
>     for (v= 0; v < p->contour[c].num_vertices; v++)
>       /* Adjust bounding box */
>       if (p->contour[c].vertex[v].x < box[c].xmin)
>         box[c].xmin= p->contour[c].vertex[v].x;
>       if (p->contour[c].vertex[v].y < box[c].ymin)
>         box[c].ymin= p->contour[c].vertex[v].y;
>       if (p->contour[c].vertex[v].x > box[c].xmax)
>         box[c].xmax= p->contour[c].vertex[v].x;
>       if (p->contour[c].vertex[v].y > box[c].ymax)
>           box[c].ymax= p->contour[c].vertex[v].y;
>   return box;
> static void minimax_test(gpc_polygon *subj, gpc_polygon *clip, gpc_op op)
>   bbox *s_bbox, *c_bbox;
>   int   s, c, *o_table, overlap;
>   s_bbox= create_contour_bboxes(subj);
>   c_bbox= create_contour_bboxes(clip);
>   MALLOC(o_table, subj->num_contours * clip->num_contours * sizeof(int),
>          "overlap table creation");
>   /* Check all subject contour bounding boxes against clip boxes */
>   for (s= 0; s < subj->num_contours; s++)
>     for (c= 0; c < clip->num_contours; c++)
>       o_table[c * subj->num_contours + s]=
>              (!((s_bbox[s].xmax < c_bbox[c].xmin) ||
>                 (s_bbox[s].xmin > c_bbox[c].xmax))) &&
>              (!((s_bbox[s].ymax < c_bbox[c].ymin) ||
>                 (s_bbox[s].ymin > c_bbox[c].ymax)));
>   /* For each clip contour, search for any subject contour overlaps */
>     overlap= 0;
>     for (s= 0; (!overlap) && (s < subj->num_contours); s++)
>       overlap= o_table[c * subj->num_contours + s];
>     if (!overlap)
>       /* Flag non contributing status by negating vertex count */
>       clip->contour[c].num_vertices = -clip->contour[c].num_vertices;
>   if (op == GPC_INT)
>     /* For each subject contour, search for any clip contour overlaps */
>       overlap= 0;
>       for (c= 0; (!overlap) && (c < clip->num_contours); c++)
>       if (!overlap)
>         subj->contour[s].num_vertices = -subj->contour[s].num_vertices;
>   FREE(s_bbox);
>   FREE(c_bbox);
>   FREE(o_table);
>                              Public Functions
> void gpc_free_polygon(gpc_polygon *p)
>   int c;
>     FREE(p->contour[c].vertex);
>   FREE(p->hole);
>   FREE(p->contour);
>   p->num_contours= 0;
> void gpc_read_polygon(FILE *fp, int read_hole_flags, gpc_polygon *p)
>   int c, v;
>   fscanf(fp, "%d", &(p->num_contours));
>   MALLOC(p->hole, p->num_contours * sizeof(int),
>          "hole flag array creation");
>   MALLOC(p->contour, p->num_contours
>          * sizeof(gpc_vertex_list), "contour creation");
>     fscanf(fp, "%d", &(p->contour[c].num_vertices));
>     if (read_hole_flags)
>       fscanf(fp, "%d", &(p->hole[c]));
>     else
>       p->hole[c]= FALSE; /* Assume all contours to be external */
>     MALLOC(p->contour[c].vertex, p->contour[c].num_vertices
>            * sizeof(gpc_vertex), "vertex creation");
>       fscanf(fp, "%lf %lf", &(p->contour[c].vertex[v].x),
>                             &(p->contour[c].vertex[v].y));
> void gpc_write_polygon(FILE *fp, int write_hole_flags, gpc_polygon *p)
>   int c, v;
>   fprintf(fp, "%d\n", p->num_contours);
>     fprintf(fp, "%d\n", p->contour[c].num_vertices);
>     if (write_hole_flags)
>       fprintf(fp, "%d\n", p->hole[c]);
>       fprintf(fp, "% .*lf % .*lf\n",
>               DBL_DIG, p->contour[c].vertex[v].x,
>               DBL_DIG, p->contour[c].vertex[v].y);
> void gpc_add_contour(gpc_polygon *p, gpc_vertex_list *new_contour, int hole)
>   int             *extended_hole, c, v;
>   gpc_vertex_list *extended_contour;
>   /* Create an extended hole array */
>   MALLOC(extended_hole, (p->num_contours + 1)
>          * sizeof(int), "contour hole addition");
>   /* Create an extended contour array */
>   MALLOC(extended_contour, (p->num_contours + 1)
>          * sizeof(gpc_vertex_list), "contour addition");
>   /* Copy the old contour and hole data into the extended arrays */
>     extended_hole[c]= p->hole[c];
>     extended_contour[c]= p->contour[c];
>   /* Copy the new contour and hole onto the end of the extended arrays */
>   c= p->num_contours;
>   extended_hole[c]= hole;
>   extended_contour[c].num_vertices= new_contour->num_vertices;
>   MALLOC(extended_contour[c].vertex, new_contour->num_vertices
>          * sizeof(gpc_vertex), "contour addition");
>   for (v= 0; v < new_contour->num_vertices; v++)
>     extended_contour[c].vertex[v]= new_contour->vertex[v];
>   /* Dispose of the old contour */
>   FREE(p->contour);
>   FREE(p->hole);
>   /* Update the polygon information */
>   p->num_contours++;
>   p->hole= extended_hole;
>   p->contour= extended_contour;
> void gpc_polygon_clip(gpc_op op, gpc_polygon *subj, gpc_polygon *clip,
>                       gpc_polygon *result)
>   sb_tree       *sbtree= NULL;
>   it_node       *it= NULL, *intersect;
>   edge_node     *edge, *prev_edge, *next_edge, *succ_edge, *e0, *e1;
>   edge_node     *aet= NULL, *c_heap= NULL, *s_heap= NULL;
>   lmt_node      *lmt= NULL, *local_min;
>   polygon_node  *out_poly= NULL, *p, *q, *poly, *npoly, *cf= NULL;
>   vertex_node   *vtx, *nv;
>   h_state        horiz[2];
>   int            in[2], exists[2], parity[2]= {LEFT, LEFT};
>   int            c, v, contributing, search, scanbeam= 0, sbt_entries= 0;
>   int            vclass, bl, br, tl, tr;
>   double        *sbt= NULL, xb, px, yb, yt, dy, ix, iy;
>   /* Test for trivial NULL result cases */
>   if (((subj->num_contours == 0) && (clip->num_contours == 0))
>    || ((subj->num_contours == 0) && ((op == GPC_INT) || (op == GPC_DIFF)))
>    || ((clip->num_contours == 0) &&  (op == GPC_INT)))
>     result->num_contours= 0;
>     result->hole= NULL;
>     result->contour= NULL;
>     return;
>   /* Identify potentialy contributing contours */
>   if (((op == GPC_INT) || (op == GPC_DIFF))
>    && (subj->num_contours > 0) && (clip->num_contours > 0))
>     minimax_test(subj, clip, op);
>   /* Build LMT */
>   if (subj->num_contours > 0)
>     s_heap= build_lmt(&lmt, &sbtree, &sbt_entries, subj, SUBJ, op);
>   if (clip->num_contours > 0)
>     c_heap= build_lmt(&lmt, &sbtree, &sbt_entries, clip, CLIP, op);
>   /* Return a NULL result if no contours contribute */
>   if (lmt == NULL)
>     result->hole= NULL;
>     reset_lmt(&lmt);
>     FREE(s_heap);
>     FREE(c_heap);
>     return;
>   /* Build scanbeam table from scanbeam tree */
>   MALLOC(sbt, sbt_entries * sizeof(double), "sbt creation");
>   build_sbt(&scanbeam, sbt, sbtree);
>   scanbeam= 0;
>   free_sbtree(&sbtree);
>   /* Allow pointer re-use without causing memory leak */
>   if (subj == result)
>     gpc_free_polygon(subj);
>   if (clip == result)
>     gpc_free_polygon(clip);
>   /* Invert clip polygon for difference operation */
>   if (op == GPC_DIFF)
>     parity[CLIP]= RIGHT;
>   local_min= lmt;
>   /* Process each scanbeam */
>   while (scanbeam < sbt_entries)
>     /* Set yb and yt to the bottom and top of the scanbeam */
>     yb= sbt[scanbeam++];
>     if (scanbeam < sbt_entries)
>       yt= sbt[scanbeam];
>       dy= yt - yb;
>     /* === SCANBEAM BOUNDARY PROCESSING ================================ */
>     /* If LMT node corresponding to yb exists */
>     if (local_min)
>       if (local_min->y == yb)
>         /* Add edges starting at this local minimum to the AET */
>         for (edge= local_min->first_bound; edge; edge= edge->next_bound)
>           add_edge_to_aet(&aet, edge, NULL);
>         local_min= local_min->next;
>     /* Set dummy previous x value */
>     px= -DBL_MAX;
>     /* Create bundles within AET */
>     e0= aet;
>     e1= aet;
>     /* Set up bundle fields of first edge */
>     aet->bundle[ABOVE][ aet->type]= (aet->top.y != yb);
>     aet->bundle[ABOVE][!aet->type]= FALSE;
>     aet->bstate[ABOVE]= UNBUNDLED;
>     for (next_edge= aet->next; next_edge; next_edge= next_edge->next)
>       /* Set up bundle fields of next edge */
>       next_edge->bundle[ABOVE][ next_edge->type]= (next_edge->top.y != yb);
>       next_edge->bundle[ABOVE][!next_edge->type]= FALSE;
>       next_edge->bstate[ABOVE]= UNBUNDLED;
>       /* Bundle edges above the scanbeam boundary if they coincide */
>       if (next_edge->bundle[ABOVE][next_edge->type])
>         if (EQ(e0->xb, next_edge->xb) && EQ(e0->dx, next_edge->dx)
>          && (e0->top.y != yb))
>           next_edge->bundle[ABOVE][ next_edge->type]^=
>             e0->bundle[ABOVE][ next_edge->type];
>             e0->bundle[ABOVE][!next_edge->type];
>           next_edge->bstate[ABOVE]= BUNDLE_HEAD;
>           e0->bundle[ABOVE][CLIP]= FALSE;
>           e0->bundle[ABOVE][SUBJ]= FALSE;
>           e0->bstate[ABOVE]= BUNDLE_TAIL;
>         e0= next_edge;
>     horiz[CLIP]= NH;
>     horiz[SUBJ]= NH;
>     /* Process each edge at this scanbeam boundary */
>       exists[CLIP]= edge->bundle[ABOVE][CLIP] +
>                    (edge->bundle[BELOW][CLIP] << 1);
>       exists[SUBJ]= edge->bundle[ABOVE][SUBJ] +
>                    (edge->bundle[BELOW][SUBJ] << 1);
>       if (exists[CLIP] || exists[SUBJ])
>         /* Set bundle side */
>         edge->bside[CLIP]= parity[CLIP];
>         edge->bside[SUBJ]= parity[SUBJ];
>         /* Determine contributing status and quadrant occupancies */
>         switch (op)
>         case GPC_DIFF:
>         case GPC_INT:
>           contributing= (exists[CLIP] && (parity[SUBJ] || horiz[SUBJ]))
>                      || (exists[SUBJ] && (parity[CLIP] || horiz[CLIP]))
>                      || (exists[CLIP] && exists[SUBJ]
>                      && (parity[CLIP] == parity[SUBJ]));
>           br= (parity[CLIP])
>            && (parity[SUBJ]);
>           bl= (parity[CLIP] ^ edge->bundle[ABOVE][CLIP])
>            && (parity[SUBJ] ^ edge->bundle[ABOVE][SUBJ]);
>           tr= (parity[CLIP] ^ (horiz[CLIP]!=NH))
>            && (parity[SUBJ] ^ (horiz[SUBJ]!=NH));
>           tl= (parity[CLIP] ^ (horiz[CLIP]!=NH) ^ edge->bundle[BELOW][CLIP])
>            && (parity[SUBJ] ^ (horiz[SUBJ]!=NH) ^ edge->bundle[BELOW][SUBJ]);
>           break;
>         case GPC_XOR:
>           contributing= exists[CLIP] || exists[SUBJ];
>           br= (parity[CLIP])
>             ^ (parity[SUBJ]);
>             ^ (parity[SUBJ] ^ edge->bundle[ABOVE][SUBJ]);
>             ^ (parity[SUBJ] ^ (horiz[SUBJ]!=NH));
>             ^ (parity[SUBJ] ^ (horiz[SUBJ]!=NH) ^ edge->bundle[BELOW][SUBJ]);
>           break;
>         case GPC_UNION:
>           contributing= (exists[CLIP] && (!parity[SUBJ] || horiz[SUBJ]))
>                      || (exists[SUBJ] && (!parity[CLIP] || horiz[CLIP]))
>           br= (parity[CLIP])
>            || (parity[SUBJ]);
>           break;
>         /* Update parity */
>         parity[CLIP]^= edge->bundle[ABOVE][CLIP];
>         parity[SUBJ]^= edge->bundle[ABOVE][SUBJ];
>         /* Update horizontal state */
>         if (exists[CLIP])
>           horiz[CLIP]=
>             next_h_state[horiz[CLIP]]
>                         [((exists[CLIP] - 1) << 1) + parity[CLIP]];
>         if (exists[SUBJ])
>           horiz[SUBJ]=
>             next_h_state[horiz[SUBJ]]
>                         [((exists[SUBJ] - 1) << 1) + parity[SUBJ]];
>         vclass= tr + (tl << 1) + (br << 2) + (bl << 3);
>         if (contributing)
>           xb= edge->xb;
>           switch (vclass)
>           case EMN:
>           case IMN:
>             add_local_min(&out_poly, edge, xb, yb);
>             px= xb;
>             cf= edge->outp[ABOVE];
>             break;
>           case ERI:
>             if (xb != px)
>               add_right(cf, xb, yb);
>               px= xb;
>             edge->outp[ABOVE]= cf;
>             cf= NULL;
>             break;
>           case ELI:
>             add_left(edge->outp[BELOW], xb, yb);
>             px= xb;
>             cf= edge->outp[BELOW];
>             break;
>           case EMX:
>             if (xb != px)
>               add_left(cf, xb, yb);
>               px= xb;
>             merge_right(cf, edge->outp[BELOW], out_poly);
>             cf= NULL;
>             break;
>           case ILI:
>             if (xb != px)
>               px= xb;
>             cf= NULL;
>             break;
>           case IRI:
>             add_right(edge->outp[BELOW], xb, yb);
>             px= xb;
>             edge->outp[BELOW]= NULL;
>             break;
>           case IMX:
>             if (xb != px)
>               px= xb;
>             merge_left(cf, edge->outp[BELOW], out_poly);
>             cf= NULL;
>             break;
>           case IMM:
>             if (xb != px)
>               px= xb;
>             break;
>           case EMM:
>             if (xb != px)
>               px= xb;
>             break;
>           case LED:
>             if (edge->bot.y == yb)
>             edge->outp[ABOVE]= edge->outp[BELOW];
>             px= xb;
>             break;
>           case RED:
>             px= xb;
>             break;
>           default:
>             break;
>           } /* End of switch */
>         } /* End of contributing conditional */
>       } /* End of edge exists conditional */
>     } /* End of AET loop */
>     /* Delete terminating edges from the AET, otherwise compute xt */
>       if (edge->top.y == yb)
>         prev_edge= edge->prev;
>         next_edge= edge->next;
>         if (prev_edge)
>           prev_edge->next= next_edge;
>         else
>           aet= next_edge;
>         if (next_edge)
>           next_edge->prev= prev_edge;
>         /* Copy bundle head state to the adjacent tail edge if required */
>         if ((edge->bstate[BELOW] == BUNDLE_HEAD) && prev_edge)
>           if (prev_edge->bstate[BELOW] == BUNDLE_TAIL)
>             prev_edge->outp[BELOW]= edge->outp[BELOW];
>             prev_edge->bstate[BELOW]= UNBUNDLED;
>             if (prev_edge->prev)
>               if (prev_edge->prev->bstate[BELOW] == BUNDLE_TAIL)
>                 prev_edge->bstate[BELOW]= BUNDLE_HEAD;
>       else
>         if (edge->top.y == yt)
>           edge->xt= edge->top.x;
>         else
>           edge->xt= edge->bot.x + edge->dx * (yt - edge->bot.y);
>       /* === SCANBEAM INTERIOR PROCESSING ============================== */
>       build_intersection_table(&it, aet, dy);
>       /* Process each node in the intersection table */
>       for (intersect= it; intersect; intersect= intersect->next)
>         e0= intersect->ie[0];
>         e1= intersect->ie[1];
>         /* Only generate output for contributing intersections */
>         if ((e0->bundle[ABOVE][CLIP] || e0->bundle[ABOVE][SUBJ])
>          && (e1->bundle[ABOVE][CLIP] || e1->bundle[ABOVE][SUBJ]))
>           p= e0->outp[ABOVE];
>           q= e1->outp[ABOVE];
>           ix= intersect->point.x;
>           iy= intersect->point.y + yb;
>           in[CLIP]= ( e0->bundle[ABOVE][CLIP] && !e0->bside[CLIP])
>                  || ( e1->bundle[ABOVE][CLIP] &&  e1->bside[CLIP])
>                  || (!e0->bundle[ABOVE][CLIP] && !e1->bundle[ABOVE][CLIP]
>                      && e0->bside[CLIP] && e1->bside[CLIP]);
>           in[SUBJ]= ( e0->bundle[ABOVE][SUBJ] && !e0->bside[SUBJ])
>                  || ( e1->bundle[ABOVE][SUBJ] &&  e1->bside[SUBJ])
>                  || (!e0->bundle[ABOVE][SUBJ] && !e1->bundle[ABOVE][SUBJ]
>                      && e0->bside[SUBJ] && e1->bside[SUBJ]);
>           /* Determine quadrant occupancies */
>           switch (op)
>           case GPC_DIFF:
>           case GPC_INT:
>             tr= (in[CLIP])
>              && (in[SUBJ]);
>             tl= (in[CLIP] ^ e1->bundle[ABOVE][CLIP])
>              && (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ]);
>             br= (in[CLIP] ^ e0->bundle[ABOVE][CLIP])
>              && (in[SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
>             bl= (in[CLIP] ^ e1->bundle[ABOVE][CLIP] ^ e0->bundle[ABOVE][CLIP])
>              && (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
>             break;
>           case GPC_XOR:
>             tr= (in[CLIP])
>               ^ (in[SUBJ]);
>               ^ (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ]);
>               ^ (in[SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
>               ^ (in[SUBJ] ^ e1->bundle[ABOVE][SUBJ] ^ e0->bundle[ABOVE][SUBJ]);
>             break;
>           case GPC_UNION:
>             tr= (in[CLIP])
>              || (in[SUBJ]);
>             break;
>           switch (vclass)
>           case EMN:
>             add_local_min(&out_poly, e0, ix, iy);
>             e1->outp[ABOVE]= e0->outp[ABOVE];
>             break;
>           case ERI:
>             if (p)
>               add_right(p, ix, iy);
>               e1->outp[ABOVE]= p;
>               e0->outp[ABOVE]= NULL;
>             break;
>           case ELI:
>             if (q)
>               add_left(q, ix, iy);
>               e0->outp[ABOVE]= q;
>               e1->outp[ABOVE]= NULL;
>             break;
>           case EMX:
>             if (p && q)
>               add_left(p, ix, iy);
>               merge_right(p, q, out_poly);
>             break;
>           case IMN:
>             break;
>           case ILI:
>             if (p)
>               e1->outp[ABOVE]= p;
>             break;
>           case IRI:
>             if (q)
>               add_right(q, ix, iy);
>               e0->outp[ABOVE]= q;
>             break;
>           case IMX:
>             if (p && q)
>               merge_left(p, q, out_poly);
>             break;
>           case IMM:
>             if (p && q)
>             break;
>           case EMM:
>             if (p && q)
>             break;
>           default:
>             break;
>         } /* End of contributing intersection conditional */
>         /* Swap bundle sides in response to edge crossing */
>         if (e0->bundle[ABOVE][CLIP])
>           e1->bside[CLIP]= !e1->bside[CLIP];
>         if (e1->bundle[ABOVE][CLIP])
>           e0->bside[CLIP]= !e0->bside[CLIP];
>         if (e0->bundle[ABOVE][SUBJ])
>           e1->bside[SUBJ]= !e1->bside[SUBJ];
>         if (e1->bundle[ABOVE][SUBJ])
>           e0->bside[SUBJ]= !e0->bside[SUBJ];
>         /* Swap e0 and e1 bundles in the AET */
>         prev_edge= e0->prev;
>         next_edge= e1->next;
>         if (next_edge)
>           next_edge->prev= e0;
>         if (e0->bstate[ABOVE] == BUNDLE_HEAD)
>           search= TRUE;
>           while (search)
>             prev_edge= prev_edge->prev;
>             if (prev_edge)
>               if (prev_edge->bstate[ABOVE] != BUNDLE_TAIL)
>                 search= FALSE;
>             else
>               search= FALSE;
>         if (!prev_edge)
>           aet->prev= e1;
>           e1->next= aet;
>           aet= e0->next;
>         else
>           prev_edge->next->prev= e1;
>           e1->next= prev_edge->next;
>           prev_edge->next= e0->next;
>         e0->next->prev= prev_edge;
>         e1->next->prev= e1;
>         e0->next= next_edge;
>       } /* End of IT loop*/
>       /* Prepare for next scanbeam */
>       for (edge= aet; edge; edge= next_edge)
>         succ_edge= edge->succ;
>         if ((edge->top.y == yt) && succ_edge)
>           /* Replace AET edge by its successor */
>           succ_edge->outp[BELOW]= edge->outp[ABOVE];
>           succ_edge->bstate[BELOW]= edge->bstate[ABOVE];
>           succ_edge->bundle[BELOW][CLIP]= edge->bundle[ABOVE][CLIP];
>           succ_edge->bundle[BELOW][SUBJ]= edge->bundle[ABOVE][SUBJ];
>           if (prev_edge)
>             prev_edge->next= succ_edge;
>           else
>             aet= succ_edge;
>           if (next_edge)
>             next_edge->prev= succ_edge;
>           succ_edge->prev= prev_edge;
>           succ_edge->next= next_edge;
>         else
>           /* Update this edge */
>           edge->xb= edge->xt;
>         edge->outp[ABOVE]= NULL;
>   } /* === END OF SCANBEAM PROCESSING ================================== */
>   /* Generate result polygon from out_poly */
>   result->hole= NULL;
>   result->num_contours= count_contours(out_poly);
>   if (result->num_contours > 0)
>     MALLOC(result->hole, result->num_contours
>            * sizeof(int), "hole flag table creation");
>     MALLOC(result->contour, result->num_contours
>     c= 0;
>     for (poly= out_poly; poly; poly= npoly)
>       npoly= poly->next;
>       if (poly->active)
>         result->hole[c]= poly->proxy->hole;
>         result->contour[c].num_vertices= poly->active;
>         MALLOC(result->contour[c].vertex,
>           result->contour[c].num_vertices * sizeof(gpc_vertex),
>           "vertex creation");
>         v= result->contour[c].num_vertices - 1;
>         for (vtx= poly->proxy->v[LEFT]; vtx; vtx= nv)
>           nv= vtx->next;
>           result->contour[c].vertex[v].x= vtx->x;
>           result->contour[c].vertex[v].y= vtx->y;
>           FREE(vtx);
>           v--;
>         c++;
>       FREE(poly);
>   /* Tidy up */
>   reset_it(&it);
>   reset_lmt(&lmt);
>   FREE(c_heap);
>   FREE(s_heap);
>   FREE(sbt);
> void gpc_free_tristrip(gpc_tristrip *t)
>   int s;
>   for (s= 0; s < t->num_strips; s++)
>     FREE(t->strip[s].vertex);
>   FREE(t->strip);
>   t->num_strips= 0;
> void gpc_polygon_to_tristrip(gpc_polygon *s, gpc_tristrip *t)
>   gpc_polygon c;
>   c.num_contours= 0;
>   c.hole= NULL;
>   c.contour= NULL;
>   gpc_tristrip_clip(GPC_DIFF, s, &c, t);
> void gpc_tristrip_clip(gpc_op op, gpc_polygon *subj, gpc_polygon *clip,
>                        gpc_tristrip *result)
>   edge_node     *aet= NULL, *c_heap= NULL, *s_heap= NULL, *cf;
>   polygon_node  *tlist= NULL, *tn, *tnn, *p, *q;
>   vertex_node   *lt, *ltn, *rt, *rtn;
>   h_state        horiz[2];
>   vertex_type    cft;
>   int            s, v, contributing, search, scanbeam= 0, sbt_entries= 0;
>   double        *sbt= NULL, xb, px, nx, yb, yt, dy, ix, iy;
>     result->num_strips= 0;
>     result->strip= NULL;
>     return;
>   /* Build LMT */
>   if (lmt == NULL)
>     reset_lmt(&lmt);
>     FREE(s_heap);
>     FREE(c_heap);
>     return;
>   scanbeam= 0;
>   if (op == GPC_DIFF)
>   local_min= lmt;
>       yt= sbt[scanbeam];
>       dy= yt - yb;
>     if (local_min)
>     px= -DBL_MAX;
>     e0= aet;
>     e1= aet;
>         e0= next_edge;
>     horiz[CLIP]= NH;
>     horiz[SUBJ]= NH;
>         switch (op)
>         case GPC_DIFF:
>         case GPC_INT:
>           br= (parity[CLIP])
>            && (parity[SUBJ]);
>           break;
>         case GPC_XOR:
>           br= (parity[CLIP])
>             ^ (parity[SUBJ]);
>           break;
>         case GPC_UNION:
>           br= (parity[CLIP])
>            || (parity[SUBJ]);
>           break;
>         /* Update parity */
>         if (exists[CLIP])
>           horiz[CLIP]=
>         if (exists[SUBJ])
>           horiz[SUBJ]=
>         if (contributing)
>           xb= edge->xb;
>           switch (vclass)
>           case EMN:
>             new_tristrip(&tlist, edge, xb, yb);
>             cf= edge;
>             break;
>           case ERI:
>             edge->outp[ABOVE]= cf->outp[ABOVE];
>             if (xb != cf->xb)
>               VERTEX(edge, ABOVE, RIGHT, xb, yb);
>             cf= NULL;
>             break;
>           case ELI:
>             VERTEX(edge, BELOW, LEFT, xb, yb);
>             cf= edge;
>             break;
>           case EMX:
>             if (xb != cf->xb)
>               VERTEX(edge, BELOW, RIGHT, xb, yb);
>             cf= NULL;
>             break;
>           case IMN:
>             if (cft == LED)
>               if (cf->bot.y != yb)
>                 VERTEX(cf, BELOW, LEFT, cf->xb, yb);
>               new_tristrip(&tlist, cf, cf->xb, yb);
>             break;
>           case ILI:
>             cf= edge;
>             cft= ILI;
>             break;
>           case IRI:
>             if (cft == LED)
>             break;
>           case IMX:
>             cft= IMX;
>             break;
>           case IMM:
>             if (xb != cf->xb)
>               VERTEX(cf, ABOVE, RIGHT, xb, yb);
>             cf= edge;
>             break;
>           case EMM:
>             cf= edge;
>             break;
>           case LED:
>             cf= edge;
>             cft= LED;
>             break;
>           case RED:
>             if (cft == LED)
>               if (cf->bot.y == yb)
>               else
>             else
>             cf= NULL;
>             break;
>           default:
>             break;
>         if (prev_edge)
>         else
>           aet= next_edge;
>         if (next_edge)
>       else
>         else
>           p= e0->outp[ABOVE];
>           q= e1->outp[ABOVE];
>           switch (op)
>           case GPC_DIFF:
>           case GPC_INT:
>             tr= (in[CLIP])
>              && (in[SUBJ]);
>             break;
>           case GPC_XOR:
>             tr= (in[CLIP])
>               ^ (in[SUBJ]);
>             break;
>           case GPC_UNION:
>             tr= (in[CLIP])
>              || (in[SUBJ]);
>             break;
>           switch (vclass)
>           case EMN:
>             new_tristrip(&tlist, e1, ix, iy);
>             e0->outp[ABOVE]= e1->outp[ABOVE];
>             break;
>           case ERI:
>             if (p)
>               P_EDGE(prev_edge, e0, ABOVE, px, iy);
>               VERTEX(prev_edge, ABOVE, LEFT, px, iy);
>               VERTEX(e0, ABOVE, RIGHT, ix, iy);
>             break;
>           case ELI:
>             if (q)
>               N_EDGE(next_edge, e1, ABOVE, nx, iy);
>               VERTEX(e1, ABOVE, LEFT, ix, iy);
>               VERTEX(next_edge, ABOVE, RIGHT, nx, iy);
>             break;
>           case EMX:
>             if (p && q)
>               VERTEX(e0, ABOVE, LEFT, ix, iy);
>             break;
>           case IMN:
>             new_tristrip(&tlist, prev_edge, px, iy);
>             e1->outp[ABOVE]= prev_edge->outp[ABOVE];
>             VERTEX(e1, ABOVE, RIGHT, ix, iy);
>             new_tristrip(&tlist, e0, ix, iy);
>             next_edge->outp[ABOVE]= e0->outp[ABOVE];
>             break;
>           case ILI:
>             if (p)
>             break;
>           case IRI:
>             if (q)
>             break;
>           case IMX:
>             if (p && q)
>               next_edge->outp[ABOVE]= prev_edge->outp[ABOVE];
>             break;
>           case IMM:
>             if (p && q)
>             break;
>           case EMM:
>             if (p && q)
>             break;
>           default:
>             break;
>         if (e1->next)
>           e1->next->prev= e0;
>           search= TRUE;
>           while (search)
>             if (prev_edge)
>               if (prev_edge->bundle[ABOVE][CLIP]
>                || prev_edge->bundle[ABOVE][SUBJ]
>                || (prev_edge->bstate[ABOVE] == BUNDLE_HEAD))
>                 search= FALSE;
>             else
>               search= FALSE;
>         if (!prev_edge)
>            e1->next= aet;
>            aet= e0->next;
>         else
>         e1->next->prev= e1;
>           if (prev_edge)
>           else
>             aet= succ_edge;
>           if (next_edge)
>         else
>           edge->xb= edge->xt;
>   /* Generate result tristrip from tlist */
>   result->num_strips= count_tristrips(tlist);
>   if (result->num_strips > 0)
>     MALLOC(result->strip, result->num_strips * sizeof(gpc_vertex_list),
>            "tristrip list creation");
>     s= 0;
>     for (tn= tlist; tn; tn= tnn)
>       tnn= tn->next;
>       if (tn->active > 2)
>         /* Valid tristrip: copy the vertices and free the heap */
>         result->strip[s].num_vertices= tn->active;
>         MALLOC(result->strip[s].vertex, tn->active * sizeof(gpc_vertex),
>                "tristrip creation");
>         v= 0;
>         if (INVERT_TRISTRIPS)
>           lt= tn->v[RIGHT];
>           rt= tn->v[LEFT];
>         else
>           lt= tn->v[LEFT];
>           rt= tn->v[RIGHT];
>         while (lt || rt)
>           if (lt)
>             ltn= lt->next;
>             result->strip[s].vertex[v].x= lt->x;
>             result->strip[s].vertex[v].y= lt->y;
>             v++;
>             FREE(lt);
>             lt= ltn;
>           if (rt)
>             rtn= rt->next;
>             result->strip[s].vertex[v].x= rt->x;
>             result->strip[s].vertex[v].y= rt->y;
>             v++;
>             FREE(rt);
>             rt= rtn;
>         s++;
>       else
>         /* Invalid tristrip: just free the heap */
>         for (lt= tn->v[LEFT]; lt; lt= ltn)
>           ltn= lt->next;
>           FREE(lt);
>         for (rt= tn->v[RIGHT]; rt; rt=rtn)
>           rtn= rt->next;
>           FREE(rt);
>       FREE(tn);
>   /* Tidy up */
>   reset_it(&it);
>   reset_lmt(&lmt);
>   FREE(c_heap);
>   FREE(s_heap);
>   FREE(sbt);
>                            End of file: gpc.c
> -- Selected TOC Entries:
> \connect - postgres
> -- TOC Entry ID 2 (OID 922575)
> -- Name: testgpc Type: TABLE Owner: postgres
> CREATE TABLE "testgpc" (
>         "id" integer,
>         "geom" geometry
> -- Data for TOC Entry ID 3 (OID 922575)
> -- Name: testgpc Type: TABLE DATA Owner: postgres
> COPY "testgpc"  FROM stdin;
> 1       SRID=-1;POLYGON((1 1,3 1,3 3,1 1))
> 2       SRID=-1;POLYGON((2 1,2 3,1 3,2 1))
> 3       SRID=-1;POLYGON((3 2,10 2,10 6,8 6,8 3,5 3,5 6,3 6,3 2),(4.5 4.5,4.5 5,3.5 5,3.5 4.5,4.5 4.5),(9.5 4.5,9.5 5,8.5 5,8.5 4.5,9.5 4.5))
> 4       SRID=-1;POLYGON((12 4,12 8,1 8,1 4,12 4))
> 5       SRID=-1;POLYGON((9 5,9 7.5,6.5 7.5,6.5 5,9 5),(8.5 5,8.5 7,7 7,8.5 5))
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020430/ca161ab1/attachment.vcf>
