[postgis] AddGeometryColumn fails -- pgsql 7.1.3 and postgis 0.6.2 okay?
Tyler Mitchell tmitchell at lignum.com
Tue Jan 15 08:22:14 PST 2002
I can see how the difference you caught was subtle.  It have done
everything as postgres user and it appears to have at least got me past the
addgeometry hurdle - though my logs didn't look much different at all.  Now
onto getting it some shapefile data and working with mapserver....
Thanks Paul.
                    Paul Ramsey
                    <pramsey at refrac       To:     postgis at yahoogroups.com
                    tions.net>            cc:
                                          Fax to:
                    01/14/2002            Subject:     Re: [postgis] AddGeometryColumn fails  -- pgsql 7.1.3 and
                    05:47 PM               postgis 0.6.2  okay?
                    Please respond
                    to postgis
Ah.
Took me two looks to see it.
In your postgis.sql upload, note that it failed 1/2 way through, when
you try to alter the opclass. The user you are uploading postgis.sql
with does not have system privileges. Try uploading postgis.sql as the
postgres user, or give your user system privs. If the postgis.sql upload
fails you get none of the necessary function defs, and hence, no
functionality.
Paul
Tyler Mitchell wrote:
> Hi listers, I'm trying postgis out for the first time, following the docs
> closely (I think), but after all is said and done I cannot use the
> AddGeometryColumn function (see end of log below).  Is it because of the
> versions I am running:
> Postgresql - 7.1.3 - installed from sources
> PostGIS - 0.6.2 - moved to pg/contrib folder and ran make; make install
> fine
> When I try to do the "SELECT AddGeometryColumn...." from the example in
the
> docs it obviously can't find it.
> Yet it tells me I've got everything I need.  Can you look at my stuff
below
> and help me?
> Tyler
> [me at myserver postgis-0.6.2]# createlang plpgsql testgis
> createlang: 'plpgsql' is already installed in database testgis
> testgis=# \i postgis.sql
> BEGIN
>        message
>  plpgsql is installed
> (1 row)
> CREATE
> psql:postgis.sql:34: NOTICE:  CREATE TABLE/PRIMARY KEY will create
implicit
> index 'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
> CREATE
> psql:postgis.sql:47: NOTICE:  CREATE TABLE/PRIMARY KEY will create
implicit
> index 'gc_pk' for table 'geometry_columns'
> CREATE
> CREATE
> psql:postgis.sql:213: NOTICE:  ProcedureCreate: type 'box3d' is not yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:223: NOTICE:  ProcedureCreate: type 'spheroid' is not
yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:247: NOTICE:  ProcedureCreate: type 'wkb' is not yet
> defined
> CREATE
> CREATE
> CREATE
> psql:postgis.sql:265: NOTICE:  ProcedureCreate: type 'chip' is not yet
> defined
> CREATE
> CREATE
> CREATE
> psql:postgis.sql:286: NOTICE:  ProcedureCreate: type 'geometry' is not
yet
> defined
> CREATE
> CREATE
> psql:postgis.sql:323: NOTICE:  ProcedureCreate: return type 'geometry' is
> only a shell
> CREATE
> CREATE
> psql:postgis.sql:753: ERROR:  pg_opclass: Permission denied.
> psql:postgis.sql:761: NOTICE:  current transaction is aborted, queries
> ignored until end of transaction block
> *ABORT STATE*
> psql:postgis.sql:768: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:775: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:782: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:789: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:796: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:803: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:810: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:817: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:819: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:827: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:833: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:839: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:845: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:851: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:857: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:863: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:866: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> psql:postgis.sql:867: NOTICE:  current transaction is aborted, queries
> *ABORT STATE*
> COMMIT
> testgis=# drop table gtest;
> DROP
> testgis=# create table gtest (ID int4, NAME varchar(20) );
> CREATE
> testgis=# SELECT AddGeometryColumn('testgis','gtest','geom',
> -1,'LINESTRING',2);
> ERROR:  Function 'addgeometrycolumn(unknown, unknown, unknown, int4,
> unknown, int4)' does not exist
>         Unable to identify a function that satisfies the given argument
> types
>         You may need to add explicit typecasts
> testgis=#
> To unsubscribe from this group, send an email to:
> postgis-unsubscribe at yahoogroups.com
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Pinpoint the right security solution for your company - FREE
Guide from industry leader VeriSign gives you all the facts.
http://us.click.yahoo.com/pCuuSA/WdiDAA/yigFAA/PhFolB/TM
