[postgis] postgis 0.7?
Roderick A. Anderson raanders at tincan.org
Thu Jan 17 18:07:14 PST 2002
On Fri, 11 Jan 2002, Paul Ramsey wrote:
> The major re-design is linked to the integration of JTS code into
> PostGIS. IE: we need a new db object structure (maybe) to most
> efficiently use an external library of C++ geometry operators, which JTS
> will be turned into. Since the JTS porting has not started yet, neither
> has the redesign.
In the mean time - I don't remember seeing anything on the list - does
0.6.2(?) or the CVS version work with PostgreSQL 7.2bX?  I'm getting
ready to bring a test server online with 7.2 and would like to have
PostGIS installed at the same time.
Best,
Rod
                      Let Accuracy Triumph Over Victory
                                                       Zetetic Institute
                                                        "David's Sling"
                                                         Marc Stiegler
------------------------ Yahoo! Groups Sponsor ---------------------~-->
Sponsored by VeriSign - The Value of Trust
Do you need to encrypt all your online transactions? Find
the perfect solution in this FREE Guide from VeriSign.
http://us.click.yahoo.com/vCuuSA/UdiDAA/yigFAA/PhFolB/TM
To unsubscribe from this group, send an email to:
postgis-unsubscribe at yahoogroups.com
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
