[Fwd: Re: [postgis-users] dataset for postgis]
Hao Ding hdi12 at it.canterbury.ac.nz
Thu Jul 4 15:43:30 PDT 2002
Hi Tyler,
I have converts the shapefile to sql file successfully. Now Could you
tell me how to set up WMS server mapfile in Mapserver for the data?
Thanks a lot!
Hao
-------- Original Message --------
Subject: Re: [postgis-users] dataset for postgis
Date: Fri, 05 Jul 2002 10:21:51 +1200
Reply-To: postgis-users at postgis.refractions.net
Organization: University of Canterbury
To: Tyler Mitchell <themitchells at telus.net>
CC: postgis-users at postgis.refractions.net
References: <3D1F480A at webmail>
<20020702050233.RUUD5909.priv-edtnes16-hme0.telusplanet.net at there>
I tried creating a sql file from Itasca demo shapefile, but got
"Segmentation fault" error. Are there some faults in the command?
cosc273:data$ shp2pgsql airports airports gisdb > airports.sql
Segmentation fault
Thanks,
Hao
Tyler Mitchell wrote:
 > hi Hao,
 > Do you have the Itasca demo data for Mapserver?  You can use the
postgis tool
 > called 'shp2pgsql' (I can give you more info if needed) to create a
SQL file
 > and then you can load the sql commands into postgis.
 > I don't have time right now but I'll gladly help walk you through it.
  I even
 > have a set of SQL files for the demo data available if you want them.
  Just
 > let me know.
 > Tyler
 > On Monday 01 July 2002 09:44 pm, you wrote:
 >>Hi all,
 >>Now I am implementing a OGC WMS client application.  I have installed
 >>MapServer as WMS server and postgis as back-end datasource.  Where can I
 >>find some spatial dataset that can be stored in the postgis and used by
 >>MapServer? If I get some dataset, how to put them into postgis and make
 >>them work with MapServer?
 >>These questions could be simple for someone, but I am a new user of
 >>MapServer and postgis, and the documents don't provide me all
information I
 >>am hunting. Thanks very much for any help?
 >>Regards,
 >>Hao
 >>_______________________________________________
 >>postgis-users mailing list
 >>http://postgis.refractions.net/mailman/listinfo/postgis-users
