[postgis-users] Re: wkb4j
James Macgill j.macgill at geography.leeds.ac.uk
Mon Jul 29 03:52:19 PDT 2002
At 20:46 27/07/2002, you wrote:
>Hello,
>WKB4J is a small Java toolkit designed to parse WKB data stored in a
>PostGIS database and convert it into Java objects. WKB4J implements the
>Simple Features Specification for SQL as defined by the OpenGIS consortium.
This message is more appropriate for our developer list so I am copying the
response there.
>WKB4J is lean and mean, meaning that speed and reduced memory footprint
>where the primary concern. WKB4J is approximately 3 to 10 times faster
>than going through the WKT format.
That's excellent news, and will definitely make using PostGIS a far more
attractive proposition.
>One other problem is that there are many Java geographical toolkit around,
>so WKB4J was built with portability in mind. Thoses concerns are
>highlighted in the design of the library. Right now, WKB4J supports the
>following toolkits: ...
>* JTS
Rob Hranac mentioned your project during a recent developer IRC session and
I think he mentioned that someone was working on integrating it with our
PostGIS module, but I can't remember who (it may even have been
you).  Given that GeoTool2 is JTS based I can't imagine that there would be
very much involved.
Robs away for the moment so I can't confirm the details.  That said, if its
as straightforward as I imagine it would be then I may look at updating the
module myself.
Many thanks for your hard work, it is much appreciated.
All the best
James
James Macgill
Center for Computational Geography http://www.ccg.leeds.ac.uk
Spell Checker (c) Creative Spelling inc (aka my dyslexic brain)
http://www.geotools.org a client side java mapping toolkit.
