[postgis-users] Problems with PostGIS and Proj4 on Cygwin
Norman Vine nhv at cape.com
Tue Jun 4 14:40:05 PDT 2002
Armin Burger writes:
>I compiled successfully Postgres 7.2/PostGIS 0.7.1 on Cygwin/Windows NT.
The
>system runs fine, only there are problems with re-projection using the Proj
4
>functionality compiled into PostGIS.
Did you install Proj4 ?
If not I have placed a Cygwin binary distribution package
of PostGIS to include the Proj files at my website
http://www.vso.cape.com/~nhv/files/cygwin/postgis.tgz
This assumes that the current Cygwin Postgres 7.2 distribution
is installed in the 'default' location as is done by the Cygwin setup
program.
Note: This is not a 'supported' distribution but I would be interested
in hearing of any problems encountered.
FYI -
Out of 18 downloads I have received several reports of using this
successfully and no reports of any problems
Cheers
Norman
