[postgis-users] Accessing PostGIS from ArcView
Armin Burger armin.burger at libero.it
Sun Jun 9 12:56:55 PDT 2002
Hi all,
I have been working on an extension for ArcView 3 to access PostGIS data. At
the moment the extension offers the functionality to
* Retrieve PostGIS data as shapefile and load them into ArcView,
  including data refresh
* Re-project PostGIS data and create shapefile
* Identify and editing of attribute information directly on the database
If you are interested, you can download the extension including source code
and needed libraries at
http://digilander.iol.it/arminburger/download/avpgcon.zip
The database access is without ODBC, using the libpq.dll functionality.
Future plans are to implement a visualization of PG data as graphics in
ArcView (instead of temporary shapefiles). The only part missing for that is
a fast and reliable algorithm to convert PostGIS geometry for different types
into ArcView Avenue representation. If anyone has already finished such work
successfully and would like to contribute, I would be glad to include it.
The extension uses the pgsql2shp.exe to create the shapefiles. That will
always open a command window what is not very elegant. To avoid this, the
compilation of a library instead of the executable would be necessary. Can
anybody tell me how much effort it would be to change the C code in order to
compile as library?
Any feedback is very welcome.
Armin
 Armin Burger
 Via della fiera, 7 -  I-39050 Cornaiano BZ -  Italy
PS: I hope the Refractions people don't mind me using their elefantino logo
in one dialog, I liked it too much.
