[postgis-users] using shp files
Cedric BERNIER cedric.bernier at thales-is.com
Fri Jun 14 08:33:24 PDT 2002
Hi all !
I use shape files created thanks to psql2shp tool with PostGIS 0.7.1 ,
then I add these shapefiles in an ArcGIS 8.1 map.
I have a trouble when I zoom into some location, at a scale of 1:3 500
00
my polygons are strange , I mean the ring is perfect but the color is
not only inside the polygon but on all the map. It seems than rings are
not detected as boundaries.
Is anyone has a similar problem ?
Is it a psql2shp bug or an ESRI one ??
Is it possible to open a shape file to see the structure ?
Thank you for your help.
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020614/83f733a3/attachment.vcf>
