[postgis-users] Newbie: Windows Install Help
Tyler Mitchell TMitchell at lignum.com
Fri Jun 21 15:22:13 PDT 2002
Boy, I was lazy, thanks for the reminder to check the docs.  This
requirement is described in the postgresql source C:
\cygwin\usr\src\postgresql-7.2.1-1\docFAQ_MSWIN document.  For the record I
got the cygipc stuff from:
http://www.neuro.gatech.edu/users/cwilson/cygutils/cygipc/index.html
I had thought it was just part of cygutils at first...oops.
                      Chris Hodgson
                      <chodgson at refractions.net>              To:       postgis-users at postgis.refractions.net
                      Sent by:                                cc:
                      postgis-users-admin at postgis.refr        Fax to:
                      actions.net                             Subject:  Re: [postgis-users] Newbie: Windows Install
                                                               Help
                      06/21/2002 03:00 PM
                      Please respond to postgis-users
I think you need the cyg-ipc package to get the gcc -O2 to work in
./configure, and you'll need it to run postgreSQL in cygwin as well. This
is described in the CYGWIN readme in the postgres sources.
Chris Hodgson
Norman Vine wrote:
> Tyler Mitchell writes:
> >I thought I might as well try too.  I can't get past ./configure for
> >postgresql.   I used your options Norman (from
> >http://postgis.refractions.net/pipermail/postgis-users/2001-Jun
> >e/000025.html)
> >but it bails on me complaining:
> >checking whether the C compiler (gcc -O2 ) works... no
> >configure: error: installation or configuration problem: C
> >compiler cannot create executables.
> Have you installed the Cygwin development packages ???
> < gcc binutils ect ... >
> Norman
> postgis-users mailing list
