[postgis-users] MORE Newbie: Windows Install Help
Paul Ramsey pramsey at refractions.net
Tue Jun 25 11:00:21 PDT 2002
Yeah, you're now in familiar territory. You are building against 7.2,
but you have not enabled 7.2 indexes in the Makefile. A quick makefile
edit will have you on your way.
P.
"Hankley, Chip" wrote:
> Thanks to everyone for the help... I am making progress, but still having
> some troubles. I got past the PostgreSQL configure statement in Norman's
> instructions -see
> http://postgis.refractions.net/pipermail/postgis-users/2001-June/000025.html
> Now, when I run make on PostGIS, I get the following warnings, and one
> error:
> Is this normal (probably not). Does anything stand out to somebody?
> PS, for the archives sake, I think my previous problem *might* have been
> that I had not set up PostgreSQL yet. Now, PostgreSQL is running OK (i.e. I
> can create and delete databases and tables).
> TIA!
> Chip Hankley
> output of 'make' from /usr/src/postgresql-7.2.1-2/contrib/postgis-0.7.1
> gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations  -g  -I.
> -I../../src/include -I/usr/local/include -DFRONTEND
> -DSYSCONFDIR='"/etc/postgresql"'   -c -o postgis_gist.o postgis_gist.c
> postgis_gist.c: In function `ggeometry_compress':
> postgis_gist.c:104: structure has no member named `pred'
> postgis_gist.c:114: structure has no member named `pred'
> postgis_gist.c:120: structure has no member named `pred'
> postgis_gist.c:126: warning: assignment makes integer from pointer without a
> cast
> postgis_gist.c:130: warning: assignment makes integer from pointer without a
> cast
> postgis_gist.c: In function `ggeometry_consistent':
> postgis_gist.c:155: structure has no member named `pred'
> postgis_gist.c:160: structure has no member named `pred'
> postgis_gist.c:166: structure has no member named `pred'
> postgis_gist.c: In function `rtree_union':
> postgis_gist.c:338: structure has no member named `pred'
> postgis_gist.c:343: structure has no member named `pred'
> postgis_gist.c:331: warning: `tmp' might be used uninitialized in this
> function
> postgis_gist.c: In function `rtree_penalty':
> postgis_gist.c:364: structure has no member named `pred'
> postgis_gist.c:368: structure has no member named `pred'
> postgis_gist.c: In function `rtree_picksplit':
> postgis_gist.c:406: structure has no member named `pred'
> postgis_gist.c:408: structure has no member named `pred'
> postgis_gist.c:453: structure has no member named `pred'
> postgis_gist.c:455: structure has no member named `pred'
> postgis_gist.c:459: structure has no member named `pred'
> postgis_gist.c:461: structure has no member named `pred'
> postgis_gist.c:499: structure has no member named `pred'
> postgis_gist.c:524: warning: assignment makes integer from pointer without a
> cast
> postgis_gist.c:525: warning: assignment makes integer from pointer without a
> cast
> postgis_gist.c:379: warning: `datum_alpha' might be used uninitialized in
> this function
> postgis_gist.c:379: warning: `datum_beta' might be used uninitialized in
> this function
> make: *** [postgis_gist.o] Error 1
> postgis-users mailing list
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
