[postgis-users] use mapserver with Postgis data
Tyler Mitchell TMitchell at lignum.com
Fri Jun 28 08:47:03 PDT 2002
Great minds think alike :)
|         |           Paul Ramsey                     |
|         |           <pramsey at refractions.net>       |
|         |           Sent by:                        |
|         |           postgis-users-admin at postgis.refr|
|         |           actions.net                     |
|         |           06/28/2002 08:38 AM             |
|         |           Please respond to postgis-users |
  |       To:       postgis-users at postgis.refractions.net        |
  |       cc:        |
  |       Fax to:        |
  |       Subject:  Re: [postgis-users] use mapserver with Postgis data                                                          |
"Hankley, Chip" wrote:
> Apparently to be able to use different machines, you have to change
> something on the PostgreSQL side to allow other connections, but I
haven't
> figured that out.
It is pretty straightforward once you know that (a) you can turn
internet sockets on (and also do performance tuning!) by adjusting a
parameter in postgresql.conf and (b) you also add an entry to the bottom
of the strangely named "pg_hba.conf" find to allow trusted access to the
server from machines in your local network, thusly:
host         all         191.168.1.0     255.255.255.0     trust
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
