[postgis-users] Linebreaks in postgis.sql
Cedric BERNIER cedric.bernier at thales-is.com
Wed Mar 27 05:36:01 PST 2002
Hello!
I try to tranfert a table from ORACLE to Postgres,
is anybody know a good way to do it?, I try to use PL/SQL unfortunately I have many fields (about 35)
so, the spooled file resulting of a SELECT order in ORACLE contained wrapped lines and it is difficult
to automatically see which carriage return represents a wrapped line and which represents the end of
the row
If anybody knows how to do.....
Thank you.
.CB.
Tyler Mitchell a écrit :
> Yeah well just don't ask me to reproduce it!  Arg.
> Do you have any plans to add searching to the mailing list archive?  I'm
> sure others have went through the same simple problems as me and I don't
> want to waste your time.
> I'm trying to run postgis.sql.  I've plpgsql install okay, but I just get a
> whack of *ABORT STATE* stuff.  It seems like I get off to bad start with
> this:
> CREATE FUNCTION POSTGIS_VERSION() returns char
> as 'select \'0.6\'::char as version'
> LANGUAGE 'sql';
> ERROR:  value too long for type character(1)
> psql:postgis2.sql:24: ERROR:  value too long for type character(1)
> Any guidance?
>                     Paul Ramsey
>                     <pramsey at refractions.net>               To:
>                     Sent by:                                 postgis-users at postgis.refractions.net
>                     postgis-users-admin at postgis.refra       cc:
>                     ctions.net                              Fax to:
>                                                             Subject:     Re: [postgis-users]
>                     03/26/2002 03:11 PM
>                     Please respond to postgis-users
> It's not just you, they're really there, and may be a bigger problem
> than we thought. Should not cause a parse error though, since we have a
> pure linux environment too (and solaris) and get no problems from those
> SQL files.
> P.
> Tyler Mitchell wrote:
> > Is it just me or does the CVS version of postgis.sql have dos version
> > linefeeds?
> > I've been trying to figure out why I get a parse error running the file,
> > yet can manually enter in the commands okay.
> > Is there something I should change in my setup.  I'm using a strict linux
> > box for the development.
> > Tyler
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>       __
>      | Paul Ramsey
>      | Refractions Research
>      | Email: pramsey at refractions.net
>      | Phone: (250) 885-0632
>      \_
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20020327/0f37ed0f/attachment.vcf>
