[postgis-users] Re: [postgis] postgis and sgi irix 5.3
Dave Blasby dblasby at refractions.net
Wed Mar 27 12:03:28 PST 2002
JiXX Kastner wrote:
> dne Wed, 27 Mar 2002 09:57:40 -0800
> "Dave Blasby" <dblasby at refractions.net> napsal(a):
> > What kind of system (exactly) are you using?  What compiler (and
> > version) are you
> > using?  If you're not using GCC, you might want to try that.
> i have ansi c compiler from sgi irix 5.3 ido (integr. devel. option)
> cdrom. can i use gcc 2.95.3 if postgresql was compiled with ansi c from
> sgi?
That shouldnt be a problem.  But, if the only problems are due to the
undefined items, you probably dont have to switch compilers.
Try adding:
#define                 BIG_ENDIAN              4321
#define                 LITTLE_ENDIAN   1234
at the top of postgis.h
dave
