AW: [postgis-users] Postigs layer in Mapserver
Düster Horst Horst.Duester at bd.so.ch
Thu Nov 14 23:31:48 PST 2002
You have to use:
DATA "the_geom from (select locarg.the_geom, locarg.oid, count(*) as
cantidad from locarg, lugar where locarg.codpostal = lugar.codigopostal
group by 1,2) as prueba using SRID=<your SRID>"
Horst
-----Ursprüngliche Nachricht-----
Von: Oscar Testa [mailto:otesta at s6.coopenet.com.ar]
Gesendet am: Donnerstag, 14. November 2002 21:26
An: postgis-users at postgis.refractions.net
Betreff: [postgis-users] Postigs layer in Mapserver
Hello, iam using Postgis layers with mapserver and php_mapscript.
When a layer data property has de simple value DATA "the_geom from
xxx", the result is correct.
But when i try the next:
group by 1,2) as prueba"
the next error appear:
MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error executing
POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
DECLARE mycursor BINARY CURSOR FOR SELECT Provincia::text,asbinary
(force_collection(force_2d(the_geom)),'NDR'),OID::text from (select
locarg.the_geom, locarg.oid, count(*) as cantidad from locarg, lugar
where locarg.codpostal = lugar.codigopostal group by 1,2) as prueba
WHERE the_geom && setSRID('BOX3D(-78.22636066 -55.575152,-48.54710934 -
20.90357)'::BOX3D, find_srid('','locarg,','the_geom') )
Any idea??
Oscar
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
