[postgis-users] Question on transform.
Wed Oct 2 21:07:54 PDT 2002
Paul Ramsey wrote:
> Luis,
> You can confirm on the proj4 mailing list (try this out using the proj4
> commandline tools) but my understanding is that proj4 mostly ignores
> geogcs transforms. There are a few exceptions to this rule, but it is
> mostly true, since proj4 was originally written without any geogcs
> transform support at all. The support which is there was retrofitted in
> later by Frank Warmerdam.
> Frank can correct me, of course... :)
Paul,
Well, I would note that PROJ.4 has support for 3/7 parameter datum shifts,
some grid file based datum and converting between geographic coordinates
systems with different ellipsoids.  It lacks some other datum shift mechanisms,
and has no concept of a prime meridian.
Best regards,
