[postgis-users] RE: Problwm with shp2pgsql.exe
YC Nyon ycnyon at pd.jaring.my
Thu Oct 10 07:04:03 PDT 2002
When I issue this command:
C:\postgresql\bin>shp2pgsql -c  pm.shp pm Geoprocessing
The output is as follows:
create table pm (gid int4 , ID int4);
select AddGeometryColumn('Geoprocessing','pm','the_geom','-1','MULTIPOLYGON',2);
begin;
Insert into pm values('0','0',GeometryFromText('MULTIPOLYGON(((0.194 0.128 ,0.19
4 0.74 ,0.846 0.74 ,0.846 0.128 ,0.194 0.128 )))',-1) );end;
However, when i check, there is no inserts or table structure to the Geoprocessing database.
Then, I tried to generate the sql statements first:
C:\postgresql\bin>shp2pgsql -c  pm.shp pm Geoprocessing > test.sql
and
C:\postgresql\bin>psql -f test.sql -d Geoprocessing
A check shows the table is present. Connection to Arcview via extensions and pgsql2shape dump works fine.
Did I miss some parameters while issueing the shp2pgsql.exe command?
FYI, I am using the native port of Postgresql 7.2.1
Regards
Nyon
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021010/c70411cb/attachment.html>
