[postgis-users] Greetings, and road data questions
Paul Ramsey pramsey at refractions.net
Fri Oct 18 11:56:26 PDT 2002
Michael Graff wrote:
> I have a Perl map generating toy that makes maps in whatever detail
> desired, given a center point and a block size.  The database works
> amazingly well for small values, but gets rather slow rather quickly,
> even with filtering out unwanted rows using the SQL query:
>         SELECT cfcc, path FROM cp WHERE path && <box definition>
>                 AND (cfcc LIKE 'A1_' OR cfcc LIKE 'A2_' ...)
You might want to test out Dave's new histogram stats features (see
earlier posts on details). The stats should allow the system to decide
whether the attribute or spatial indexes will be more selective for a
given query, and choose appropriately. In the default (non-stats)
situation, the spatial is always used. On mid-sized queries on TIGER
though, you might get burned both ways -- using spatial, you get a hugh
window of data which is then sequence scanned for the attribute values;
using attribute, you get the whole dataset filtered quickly by
attribute, but the results must then be windowed spatially.
I would also be interested in a quantification of the 'gets slow
quickly'. Does the database get slow, or does the perl application
processing the data get slow, or a measurable combination of the two?
Any GIS app, when hit with enough data volume, will get slow, hence all
the various strategies for using data which is "scale appropriate" for
the task. TIGER is "scale appropriate" for local level mapping, but
quickly because needlessly detailed as the view gets wider.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
