[postgis-users] Re: truly_inside
Paul Ramsey pramsey at refractions.net
Mon Oct 21 09:03:28 PDT 2002
Yes and no. The full Relate() method is still under construction (but
quite quite close).
You can test overlaps/touchs indirectly though, using the Distance()
function, which is good enough for the purpose. A Distance() = 0 implies
that the objects either touch, overlap, or contain; ie, they share some
part of their area.
P.
Juanse wrote:
> Paul
> on january 2002 this fellow ask for the question of "a way to check
> whether polygon A intersects/ (overlaps) with polygon B? Both polygons
> can have arbitrary shapes.
> you answer that it was in the To Do list
> http://postgis.refractions.net/pipermail/postgis-users/2002-January/000567.html
> Is it already implemented?
> Juanse
> temuko-chile
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.401 / Virus Database: 226 - Release Date: 10/10/02
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
