[postgis-users] Re: truly_inside
Juanse georef at tie.cl
Mon Oct 21 10:05:30 PDT 2002
Paul
Is the distance() method too slow, i am runnig
select count(*) t0,t1 where distance(t0.wkb_geomtry, t1.wkb_geometry)= 0 and
(t0.nombre = 'Galvarino')
and it takes for ages
t0 have 31 records
t1 have 1321 records
Juanse
temuko-chile
----- Original Message -----
To: Juanse <georef at tie.cl>
Cc: <postgis-users at postgis.refractions.net>
Sent: Monday, October 21, 2002 1:03 PM
Subject: [postgis-users] Re: truly_inside
> Yes and no. The full Relate() method is still under construction (but
> quite quite close).
> You can test overlaps/touchs indirectly though, using the Distance()
> function, which is good enough for the purpose. A Distance() = 0 implies
> that the objects either touch, overlap, or contain; ie, they share some
> part of their area.
> P.
> Juanse wrote:
> > Paul
> > on january 2002 this fellow ask for the question of "a way to check
> > whether polygon A intersects/ (overlaps) with polygon B? Both polygons
> > can have arbitrary shapes.
> > you answer that it was in the To Do list
http://postgis.refractions.net/pipermail/postgis-users/2002-January/000567.h
tml
> > Is it already implemented?
> > Juanse
> > temuko-chile
> > Outgoing mail is certified Virus Free.
> > Checked by AVG anti-virus system (http://www.grisoft.com).
> > Version: 6.0.401 / Virus Database: 226 - Release Date: 10/10/02
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> postgis-users mailing list
