[postgis-users] Re: truly_inside
David Blasby dblasby at refractions.net
Mon Oct 21 13:04:16 PDT 2002
> the simple && solutions works great.
> I will try a benchmark against mapinfo intersect, after running the more
> sofisticated solution with the gist index.
The distance function isnt very accurate when things either 'just' touch or are
really-really close to touching  (you might get zero or you might get a very
small number).
dave
