[postgis-users] configure error
Armin Burger armin.burger at libero.it
Tue Oct 22 05:03:20 PDT 2002
Roland,
is the cygipc ipc-daemon running correctly? If I remeber well, I once got a similar error when cygipc was not started.
Armin
> Hello,
> I tried to configure postgis like it is explained in "The NON-UNIX User's
> Guide to Installing PostGIS on Windows".
> PostgreSQL was installed as a service and runs.
> The source code of PostgreSQL is also installed.
> And gcc, gcc2, gcc-mingw are available.
> When I try to configure the following message returns:
> postgres at ROCKY /usr/src/postgresql-7.2.2-1
> ./configure --enable-multibyte --with-CXX --prefix=/usr --sysconfdir=/etc
> docdir=/usr/doc/postgresql-$version
> loading cache ./config.cache
> checking host system type... i686-pc-cygwin
> checking which template to use... win
> checking whether to build with locale support... no
> checking whether to build with recode support... no
> checking whether to build with multibyte character support... yes, default
> SQL_A
> SCII
> checking whether NLS is wanted... no
> checking for default port number... 5432
> checking for default soft limit on number of connections... 32
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> using CFLAGS=-O2
> checking whether the C compiler (gcc -O2 ) works... no
> configure: error: installation or configuration problem: C compiler cannot
> create executables.
> Does anyone knows what's going wrong?
> postgis-users mailing list
