[postgis-users] configure error
Norman Vine nhv at cape.com
Tue Oct 22 05:26:15 PDT 2002
Armin Burger writes
> is the cygipc ipc-daemon running correctly? If I remeber well,
> I once got a similar error when cygipc was not started.
AFAIK cygipc shouldn't need to be running to make an
executable,  and it must be started or else PostgreSQL
wouldn't be up and running.
But your post did jog my mind :-)
Armin
Does the user postgres at ROCKY have sufficient privilige to
create executables in /usr/src/postgresql-7.2.2-1 ??
As I mentioned in my earlier post 'ntsec' is now turned on by
default and is strictly enforced !
Try building again after logging in as a user with sufficient privelige
If 'ntsec' doesn't mean anything to you see
http://cygwin.com/cygwin-ug-net/ntsec.html
HTH
Norman
> > I tried to configure postgis like it is explained in "The NON-UNIX
User's
> > Guide to Installing PostGIS on Windows".
> > PostgreSQL was installed as a service and runs.
> > The source code of PostgreSQL is also installed.
> > And gcc, gcc2, gcc-mingw are available.
> > When I try to configure the following message returns:
> > postgres at ROCKY /usr/src/postgresql-7.2.2-1
> > checking whether the C compiler (gcc -O2 ) works... no
> > configure: error: installation or configuration problem: C compiler
cannot
> > create executables.
> > Does anyone knows what's going wrong?
