[postgis-users] configure error
Norman Vine nhv at cape.com
Wed Oct 23 04:38:56 PDT 2002
Roland Forster writes:
> the following i tried,
> but doesn't work ...
> > but the good news is that I managed to build todays PostGIS source
> > with the following
Roland
I guess one of our mail clients changed the formatting
and broke the script
I have attached a slightly modified script this time
Copy this into your top postgres source directory
/usr/src/postgres-XXXX
and execute it from there
  % prep_postgis.sh
Then cd into your postgis directory
  % cd contrib/postgisXXXX
and try making PostGIS
  % make
the XXXX's above reflect version numbers if any
HTH
Norman
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021023/31eb58e8/attachment.obj>
