[postgis-users] RV: How export a postgreSQL/GIS
Juanse georef at tie.cl
Thu Oct 24 11:20:56 PDT 2002
We solved by using
pg_dump -f tablas.sql ejercicio
and dumps everything
Juanse
temuko-chile
  ----- Original Message -----
  To: postgis-users at postgis.refractions.net
  Sent: Thursday, October 24, 2002 2:15 PM
  Subject: Re: [postgis-users] RV: How export a postgreSQL/GIS
  Actually, I'm told that you won't get views dumped if you use this method, whereas -t "*" dumps the views as well.
  Chris
    Sent: Thursday, October 24, 2002 10:05 AM
    At first, it doesn't seem possible to use pg_dump to dump sequences - it says on the man page:
    "pg_dump will save the information necessary to re-generate all user-defined types, functions, tables, indexes, aggregates, and operators."
    That seems to be a rather complete list that doesn't contain "sequences" - in fact they aren't mentioned anywhere in the doc.
    However, after more careful reading, sequences aren't treated as special entities by postgres, they are just tables on which the nextval, setval, etc. functions work. I guess because of their status as "sequences", -t "*" doesn't include them. However, if you either specify the name of the sequence specifically using -t seq_name or simply leave out the -t parameter altogether, sequences do get dumped (as tables, with setval() function calls afterward).
    So try:
    And I think you will get everything dumped.
    Chris
      Sent: Wednesday, October 23, 2002 9:45 PM
      Subject: [postgis-users] RV: How export a postgreSQL/GIS
      I am trying to export a postgreSQL/postGIS database to on other computer.
      we are doing a :
      pg_dump -t "*" -f tablas.sql ejercicio
      to prepare the table to ftp it.
      how ever we get everything out except the sequences on the new "tablas" database.
      what are we doing wrong? or better how we should do it?
      Juanse
      temuko-chile
      Outgoing mail is certified Virus Free.
      Checked by AVG anti-virus system (http://www.grisoft.com).
      Version: 6.0.401 / Virus Database: 226 - Release Date: 10/10/02
      Version: 6.0.401 / Virus Database: 226 - Release Date: 09/10/02
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20021024/bd4b000e/attachment.html>
