[postgis-users] Zoom problems
Chris Hodgson chodgson at refractions.net
Mon Sep 23 16:47:01 PDT 2002
What sort of interface are you using to pan/zoom etc? One that you developed
yourself using mapscript? It seems likely that your list of layers is
getting lost, so you are just showing a blank page (try changing the
background color in your mapfile to test if this is the case). It is also
possible that your extents after panning/zooming and doing an incorect
calculation either very big, or very small, or do not intersect with you
data (do the extents you are sending mapserver after zooming/panning
actually contain data?).
It is very likely that either your layers or extents are getting messed up
in the pan/zoom process and this is what is causing your problem, do some
debugging by looking more closely at those variables of your mapserver
request.
Chris
> Hi all!
> When i start mapserver for first time, i see the my map very o.k., but
when i want to "zoom in or zoom out or pan" in the map...., the next map
that i see appear totally in white (nothing appear in the map either in the
legend)!!!
> i changed the values in the "EXTENT" section,
> and restart the mapserver  ...then it's see again everything ok... the
problem exist when i try to do again something in the map
> i am using:
> postgres 7.2
> mapserver 3.6.1
> postgis 0.7.1
> apache 1.3.26
> debian potato
> mpaserv -v OUTPUT=PNG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> ¿what i am doing wrong?
> Regards
> EXTENT 170000 2200000 430000 2400000
> LAYER
>   NAME Guanajuato
>   TYPE LINE
>   STATUS OFF
>   CONNECTIONTYPE postgis
>   CONNECTION "user=postgres  dbname=prueba
>    host=10.0.0.1"
>   DATA "the_geom from denspob"
>   LABELITEM pob_2000
>   CLASS
>     NAME "MANZANAS"
>     COLOR 0 0 0
>     OUTLINECOLOR 0 0 0
>     LABEL
>       FONT "Arialn"
>       COLOR 110 0 0
>       SIZE MEDIUM
>       POSITION cc
>     END
>   END
> END # Layer
> Get your free email from www.linuxmail.org
> Powered by Outblaze
> postgis-users mailing list
