AW: AW: AW: [postgis-users] PostGIS compiling error
Düster Horst Horst.Duester at bd.so.ch
Fri Aug 8 10:02:08 PDT 2003
Paul,
There is a problem with the tar you send me. The file
source/examples/Makefile.in is missing. I'm not able to run configure.
Horst
-----Ursprüngliche Nachricht-----
Von: Paul Ramsey [mailto:pramsey at refractions.net]
Gesendet am: Freitag, 8. August 2003 16:23
An: PostGIS Users Discussion
Betreff: Re: AW: AW: [postgis-users] PostGIS compiling error
Good idea...
P.
Düster Horst wrote:
> Paul,
> I only pulled postgis-cvs. Should I pull geos-cvs also? Please send me a
new
> geos-cvs.ta.gz due to I can't connect to geos cvs. It would be great you
may
> publish a nightly build or something else at the geos page.
> Horst
> Gesendet am: Freitag, 8. August 2003 16:12
> Betreff: Re: AW: [postgis-users] PostGIS compiling error
> All the latest CVS pulls? I just did a pull and things which were broken
> ceased to be.
> P.
> Düster Horst wrote:
>>Ok I forgot to say that geos is installed under /usr/local/lib and
>>/usr/local/include/geos
>>Horst
>>Von: Düster Horst [mailto:Horst.Duester at bd.so.ch]
>>Gesendet am: Freitag, 8. August 2003 08:38
>>An: 'postgis-users at postgis.refractions.net'
>>Betreff: [postgis-users] PostGIS compiling error
>>The compilation process of postgis-cvs crashes with the following error
>>message:
>>postgis_geos_wrapper.cpp:16: namespace `geos' undeclared
>>What's the reason?? Any hint??
>>Regards
>>Horst
>>Mit freundlichen Grüssen
>>Dr. Horst Düster
>>Leiter
>>Abteilung SO!GIS Koordination
>>Rötihof
>>4500 Solothurn
>>Tel.: 032 627 25 32
>>Fax: 032 627 22 14
>>horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
>> <http://www.sogis.so.ch/> www.sogis.so.ch
>>_______________________________________________
>>postgis-users mailing list
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
