AW: AW: [postgis-users] PostGIS compiling error
Norman Vine nhv at cape.com
Fri Aug 8 09:24:21 PDT 2003
Düster Horst writes:
> There is a problem with the tar you send me.  The file
> source/examples/Makefile.in is missing. I'm not able to run configure.
Just run the 'autogen.sh'  script in the top directory
FWIW
Actually there probably shouldn't be *any* 'Makefile.in's in the tarball
as they really don't belong in the CVS same for the libtool files
as these are *very* system and local machine dependent and are all
easily onstructed by the autogen.sh script
HTH
Noman
