[postgis-users] itemnquery limitation
Tom Melhuish tmelhuish at webinsightsinc.com
Mon Aug 11 10:20:15 PDT 2003
Dave,
I'm running Mapserver 4.0, Postgres 7.3.2 & Postgis 0.7.4 on linux.
tom
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of David
Blasby
Sent: Monday, August 11, 2003 12:27 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
Tom Melhuish wrote:
> Dave,
> Sorry, I was out on Friday. Attached is the PG_DUMP of my nodes table
> (nodescomb_2003.sql) along with the sql statements (NodeTbl_2003.sql) that
I
> actually used to create the table. I'm using perl to create the html file
> that calls mapserv, so I copied the source (test.html) along with the map
> file (WCms.map) to help you recreate the problem at your location. Let me
> know if you need anything else.
Thanks - did you check to see if you had the correct version of
libpq.dll (and no others) on your system?
Are you running on linux or windows?
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
