[postgis-users] itemnquery limitation
Tom Melhuish tmelhuish at webinsightsinc.com
Wed Aug 13 05:02:50 PDT 2003
Dave,
I installed Postgres 7.3.4, postgis 0.7.5 and the nightly CVS build of
Mapserver. I'm running RH8.0 & Apache 2.0.40. I dropped the database and
reproduced it like the postgis website states for an upgrade. I'm using the
mappostgis.c that came with the nightly build since the one you sent doesn't
work for some reason. Unfortunately I still get the same problem.
I have attached my perl script that I use along with the config file. You
will have to change the config file to match your database connection. Here
and example URL to use the script.
http://yourservername/cgi-bin/wc/WCMapserv.pl?MainOption=FindNodes&NodeType=
BASE&SchoolInfo=308+APEX+ELEMENTARY&CalendarYear=2003-2002
Maybe you could send me your scripts to run on my server to test them out to
see if they run fine on my server.
If you like to look at it on my server the link is:
Nodeid > 0
http://68.100.140.169:7780/cgi-bin/wc/WCMapserv.pl?MainOption=FindNodes&Node
Type=BASE&SchoolInfo=308+APEX+ELEMENTARY&CalendarYear=2003-2002
Nodeid less then 21 items
http://68.100.140.169:7780/cgi-bin/wc/WCMapserv21.pl?MainOption=FindNodes&No
deType=BASE&SchoolInfo=308+APEX+ELEMENTARY&CalendarYear=2003-2002
tom
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of David
Blasby
Sent: Tuesday, August 12, 2003 1:55 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
Tom,
I made a WCms_nodes.html that just had "nodeid=[nodeid]" in it.
Everything seems to work fine through the http server - small queries
and big queries.
I'm completely unable to reproduce the "hang".
dave
ps. do you have a recent version of libpq.so on your linux box?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030813/52c472ae/attachment.obj>
Type: application/x-perl
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030813/52c472ae/attachment.bin>
