[postgis-users] Help please
Daniel Morissette morissette at dmsolutions.ca
Wed Aug 13 10:08:09 PDT 2003
Zamil Murji wrote:
> I am running apache version 2.0.x (don't know what the x is) on a red hat 7.3 machine. I am trying to upgrade to version 2.0.47. What version are you testing on? Can you send me your httpd.conf file so that I may diff it against mine (the only thing different should be the server specific info)
Have you tried running at the command line as user apache (or whatever
user your httpd uses)?  Maybe the bug is triggered by a file permission
issue.  Also make sure that if you have a LD_LIBRARY_PATH set that it is
set to the same value in the web server and at the command line when you
do your tests.
  DM Solutions Group              http://www.dmsolutions.ca/
