[postgis-users] error running postgis.sql
Chris Faulkner chrisf at oramap.com
Wed Aug 20 05:14:17 PDT 2003
Hello
I have successfully built, installed postgres 7.3.2 and postgis 0.7.5. I am
using the template1 database, createlang worked OK.
When I run postgis.sql, I get this
ERROR - stat failed on file '$libdir/libpostgis... '
when it is running the first 2d histogram CREATE FUNCTION command in
postgis.sql.
The shared library it wants is installed, within a location on the
LD_LIBRARY_PATH when I started postmaster and psql.
Is $libdir a built-in variable. How and when is it set ?
Thanks
Chris Faulkner
