[postgis-users] error running postgis.sql
Obe, Regina DND\MIS robe.dnd at ci.boston.ma.us
Wed Aug 20 05:24:57 PDT 2003
On cygwin - I've never been successful in getting that to work so I just
change $libdir in the postgis.sql with the path to the lib folder e.g.
/lib
-----Original Message-----
Sent: Wednesday, August 20, 2003 8:14 AM
To: PostGIS Users Discussion
Subject: [postgis-users] error running postgis.sql
Hello
I have successfully built, installed postgres 7.3.2 and postgis 0.7.5. I am
using the template1 database, createlang worked OK.
When I run postgis.sql, I get this
ERROR - stat failed on file '$libdir/libpostgis... '
when it is running the first 2d histogram CREATE FUNCTION command in
postgis.sql.
The shared library it wants is installed, within a location on the
LD_LIBRARY_PATH when I started postmaster and psql.
Is $libdir a built-in variable. How and when is it set ?
Thanks
Chris Faulkner
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
