[postgis-users] GEOS link needed
Andrea Aime andrea.aime at aliceposta.it
Thu Dec 4 12:12:58 PST 2003
On Thursday 04 December 2003 20:27, krishna kumar wrote:
> Hi Andrea Aime and everybody,
>       I'm using Redhat linux 9 . I have installed postgresql7.4, proj4
> using rpm.now i need to install geos.. its seems some dependencies are not
> satisfying, can u give me the link of the geos version u installed and how
> did u install it., wats the procedure. and is their any rpm for installing
> postgis0.8.... if not should i build it myself from the postgresql source
> tree ???..
If you want to do like me, you will have to compile from sources,
and you need a properly configured set of postgres sources to compile postgis. The same holds true for
