[postgis-users] shp2pgsql and schemas
    Seamus Thomas Carroll
    carrolls at cpsc.ucalgary.ca
    Fri Dec 12 15:02:07 PST 2003
The updated code is:
input := ''ALTER TABLE '' || quote_ident(schema_name) || ''.'' || quote_ident(table_name) || '' ADD COLUMN '' || quote_ident(column_name) || '' geometry '';
RAISE NOTICE ''input: %'', input;
EXECUTE input;
RAISE NOTICE exec finished;
And the new output is:
psql:toload.txt:2: ERROR:  syntax error at or near "exec"
CONTEXT:  compile of PL/pgSQL function "addgeometrycolumn" near line 43
No output is given for the first RAISE NOTICE.  The the_geom column is
still not added to the created table.
Seamus
On Fri, 12 Dec 2003, David Blasby wrote:
> Seamus Thomas Carroll wrote:
> > I have changed the code to:
> > EXECUTE input;
> > and the output is now:
> > psql:toload.txt:2: NOTICE:  input: ALTER TABLE roads.carrolls_route_alberta_test ADD COLUMN the_geom geometry
> > psql:toload.txt:2: ERROR:  syntax error at or near "$3" at character 70
> > CONTEXT:  PL/pgSQL function "addgeometrycolumn" line 69 at return
> > if I copy the result of the notice and paste it into the psql prompt it
> > works without error.
> > Could this be a error in posgtres that is causing a syntax error when one
> > is not present?
> Try putting a "RAISE NOTICE exec finished" immediately after the EXECUTE.
> dave
> postgis-users mailing list
