[postgis-users] Connection Prob: Mapserv -> PostGIS (was: shp2img OK, mapserver not OK)
Paul Ramsey pramsey at refractions.net
Sat Feb 1 09:27:01 PST 2003
Try changing your STATUS to DEFAULT and see what happens.
P.
Bill Wheaton wrote:
> Listers:
> This is a follow up to a request for help from last week.  I'm still
> having problems getting mapserver to create an image from a postgis data
> source.
> PostGIS is working correctly.  Started with the -i option, can connect
> to it on the command line and through phppgadmin.  So it is accepting
> tcp/ip connections.
> I have geometry in postGIS.  Ran shapefile loader.  Created indexes as
> described in postGIS documentation.  Can query for geometry on command
> line.
> Mapserver is installed and working correctly.  Was built with postgis
> support.  Generates images from shapefile data sources.
> The layer portion of my  mapfile looks like this:
> LAYER
>      CONNECTIONTYPE postgis
>      NAME "countries"
>      CONNECTION "user=postgres dbname=test host=machine.domain.com"
>      DATA "the_geom from cntry_tab"
>      STATUS ON
>      TYPE POLYGON
>      CLASS
>        COLOR 205 92 82
>      END
> END
> The result is always a white box...
> In the connection string, I have tried:
> 1) with password, and without password
> 2) with port=5432 and without port=5432
> 3) with host= 'localhost', '127.0.0.1', '192.168.0.2' (the internal IP
> address of the machine), and 'machine.local' and 'machine.domain.com'.
> 4) I have also done some things suggested on the mapserver lists including:
> making sure postgresql.conf has tcpip_socket=true
> making sure pg_hba.conf includes a line for my machine...
> The frustrating thing about this is that I can get no information from
> mapserv or postgis about the nature of the problem.  In other words, I
> can't find any error message to help locate the problem.  The mapserv
> log file indicates successful completion of the request and shp2img
> creates the image correctly with no indication of any errors.  Is there
> any other log file that might direct me to the nature of the problem?
> Again-- my environment is:
> Mapserver 3.6.4 (with postgis support)
> postgres 7.3.1
> postgis from the cvs as of about 1/25/03.
> everything was built on and is running on Macos X 10.2.3
> Thanks again for any suggestions for further troubleshooting ideas.
> Bill
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
