[postgis-users] Migration from SQLServer to PostGIS
Vinko Vrsalovic vinko at cprsig.cl
Wed Feb 5 23:10:57 PST 2003
Hello Vinko,
> 	- Do multiple geom columns on the table, one for each SRID, and
> 	  then write a stored procedure (or a script, or whatever)
> 	  to build the final table
I guess this should work. (It did, at least it looks like it did, I
still haven't rendered graphically the results)
> 	I've done:
> 	select * from spatial_ref_sys where proj4text like '%latlon%';
> 	But no results are given.
You didn't obtain results because the PROJ.4 text for latlon is
'longlat' (the SRID is 4326)
Vinko Vrsalovic <el[|- at -|]vinko.cl>
