[postgis-users] Schemas in 7.3
Paul Ramsey pramsey at refractions.net
Thu Feb 6 12:35:55 PST 2003
7.3 is starting to stabilize now (7.3.2 was just released) so more and
more people are going to be using it, and by extension using PostGIS
with it.
One of the new 7.3 features is support for "schemas". Schemas
essentially partition a single database into multiple namespaces, which
can have different priviledge levels. So it becomes possible to have
multiple "different" databases in the same simple database. The reason
to do this is so that "related" applications can share data while
keeping their application-specific data separate.
So the "tax collection" branch can have all their tax table, but have
access to a general "citizen registry" table in another schema which
they have only read access to.
Basically schemas are a means of managing complex relationships between
different users and user groups. Often PgSQL administrators would solve
the problem by partitioning different groups into different databases.
But what if the groups wanted to share data? It is not possible ot join
tables across databaes. Schemas are the answer.
Right now, PostGIS gets loaded into the schema which psql has connected
to. If you are loading as the 'postgres' user, then your PostGIS support
functions and objects will get loaded into the system schema. If you are
loading as another user, then they'll end up somewhere else (like your
personal schema, for example). So, the question is: where should PostGIS
support get loaded? Should we enforce any particular loading location,
or just "let it all hang out" like we are doing now? The trouble with
the current way of doing things is that it is possible for people to
mess up their install in subtle ways, by loading PostGIS into some
non-system schema which ordinary users have no (or partial) access to.
Food for healthy thoughts,
Paul
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
