[postgis-users] OLE Db Postgis
Carl Anderson candrsn at mindspring.com
Mon Feb 10 17:39:51 PST 2003
Frank Wamerdam
I dug up a license for VC98 to compile a PostgreSQL client and GDAL.
Your recent changes to CVS for gdal allow a working PostGIS to run.
I tested using
set PGHOST=pggis.my.net
set PGUSER=myuser
set PGPASS=mypass
   ogrinfo -ro -sql "select * from daccess where geo_oid < 100"
   sfcdump.exe -provider Softmap.SF.Shape -ds PG:dbname=roads -table
so both the direct PostgreSQL conenction and the OLE Dd pass through
things not working:
   I had a table with an invalid datatype id,  it was crashing ogrinfo.
      Error trapping needs to be improved
   Neither access form above allows the environment vars to be embedded
   The -cmd "sql" part of OLE Db is broken
I am willing to put some time into this
what I want to do is add/change things so that I can run
  ogrinfo -ro -sql "select * from bob.daccess where geo_oid < 100"
that would be allowing
   schema names, sql stmts, and extra options
     (ok the example sql stmt already works but I want to fix it for
I also would like to
    move the table ident routines to use a view pg_tables (created if
necessary in older PostgreSQLs), so that schema(catalog) support can
work.  Data
scoping rules are handled by the psuedo table pg_tables in 7.3.
Before I take this on I would like to confirm with the PostGIS list the
direction re schemas, PostGIS will take.
Carl Anderson
New Hampshire tells us "common sense for all"
     where can I get mine?
