[postgis-users] shp2pgsql
Jeff Lounsbury jeffloun at refractions.net
Fri Feb 14 16:38:03 PST 2003
Also, while I was poking around shp2pgsql today....
Commited chaneges to cvs which added support for larger columns so if
they are defined in the dbf file to be larger than int4 , it will detect
it and use an int 8 or numeric type if the field requires. Same thing
for floats, uses a numeric after it goes beyond the float8 size...
