[postgis-users] Documentation on GIS specific SQL
Paul Ramsey pramsey at refractions.net
Thu Feb 20 09:43:32 PST 2003
Matt Lynch wrote:
> But it appears that I must group in order to use extent
Yes, because extent is one of two (the other is collect()) aggregate
functions currently in PostGIS. "select extent(geom) from tbl" returns
the aggregate extent of every feature in the table, ie. the extent of
the table itself.
You can get the bounding box of a single geometry with either the
OpenGIS-standard envelope() or by casting the object to a box3d with
box3d(). You can also use the xmin(), ymin() etc functions to get the
extents directly, which might be more convenient for accessing them from
a database cursor, rather than parsing the values out of an envelope or
bounding box string.
P.
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
