[postgis-users] Documentation on GIS specific SQL
David Blasby dblasby at refractions.net
Thu Feb 20 09:54:46 PST 2003
The reason you're having problems is because extent() is an aggregate
function - like min() or max().
To convert a geometry to a bounding box:
SELECT geom::box3d FROM <Table>
SELECT BOX3D(geom) FROM <table>
Use extent() when you want to find the COMBINED bounding box of several
SELECT extent(property_polygon) FROM property WHERE owner = 'dblasby';
SELECT owner, extent(property_polygon)  FROM property GROUP BY owner;
This of this like the min() and max() functions:
SELECT max(salary) FROM employees WHERE title = 'analyst';
SELECT title,max(salary) FROM employees GROUP BY title;
