[postgis-users] argument type cstring does not exits
Paul Ramsey pramsey at refractions.net
Mon Feb 24 22:02:11 PST 2003
Are you sure the running instance you are installing into is PgSQL
7.3.X? Connect to the database and run 'select version();'.
Toshimi Minoura wrote:
> 1) We installed PostgreSQL 7.3.2, and it seems to be working correctly.
> 2) We then installed PostGIS 0.7.4 with make and make install.
> 3) We issued the following command:
>    createlang plpgsql zpostgis     -- zpostgis is a database name
>    Now, plpgsql_call_handler can be seen as a function in zpostgis.
> 4) Now, when we issue the command
>    psql -d zpostgis -f postgis.sql
>    we get an error:
>       "argument type cstring does not exit"
>   This error comes from the first create function statement:
>        create function histogram2d_in(CSTRING) returns histogram2d as '
>    Type CSSTRING is indeed not in pg_type. We can create other functions
>    using types found in pg_type.
> What do we need to install to make CSSTRING defined?
> We will appreciate any help.
> Please send a reply to minoura at cs.orst.edu also.
> Toshi
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
