[postgis-users] Cygwin / PostgreSQL / PostGIS installation
Henry Holland hjholland at gmx.net
Tue Feb 25 03:18:12 PST 2003
Okay, I've created a table or two, imported a shape file etc. and it
seems to be working. I've also compiled it with Proj4 and statistics.
For Proj4 one must remember to change the following line in the postgis
makefile as well:
# Add libraries that libpq depends (or might depend) on into the
# shared library link.  (The order in which you list them here doesn't
# matter.)
#SHLIB_LINK=$(filter -L%, $(LDFLAGS))
ifeq ($(USE_PROJ),1)
      SHLIB_LINK=$(filter -L%, $(LDFLAGS)) -L$(PROJ_DIR)/lib -lproj
../../src/backend/libpostgres.a
else
endif
All the 'undefined...' warnings seem to come from the fact that the
loader can't get to the libpostgres.a library.
Cheers,
Henry
> -----Original Message-----
> From: christian.schuster at rsag.ch [mailto:christian.schuster at rsag.ch]
> Sent: 24 February 2003 16:59
> To: hjholland at gmx.net; PostGIS Users Discussion
> Cc: 'PostGIS Users Discussion';
> postgis-users-bounces at postgis.refractions.net
> Subject: RE: [postgis-users] Cygwin / PostgreSQL / PostGIS
> installation
> I found two solutions for building and installing PostGIS.
> 1. Change in the Makefile like following
> # matter.)
> else
> endif
> 2. Change the Makefile like following
> # Select proper GiST support C file
> ifeq ($(USE_VERSION),71)
>       GIST_SUPPORT=71
>       GIST_ESTIMATE=
> else
>       GIST_SUPPORT=72
>       GIST_ESTIMATE= #postgis_estimate.o
> endif
> OBJS=postgis_debug.o postgis_ops.o postgis_fn.o postgis_inout.o
> postgis_proj.o postgis_chip.o postgis_transform.o
> postgis_gist_$(GIST_SUPPORT).o $(GIST_ESTIMATE)
> # matter.)
> else
> endif
> Henry, I just installed PostgreSQL. I configure PostgreSQL
> just like this
> ./configure --with-java. I did not have any troubles. One
> question. Did you
> also install the package Perl in Cygwin?
> Can you send me a print of your ./configure or make output? I
> am really not
> an expert in all of these topics. But I spent already many
> hours on it. It
> may be that I can help you.
> Regards,
> Christian Schuster
> Rudolf Schuster AG
> Postfach 277
> CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
>              "Henry Holland"
>              <hjholland at gmx.ne
>              t>
>           To
>              Sent by:                  "'PostGIS Users
> Discussion'"
>              postgis-users-bou
> <postgis-users at postgis.refractions.
>              nces at postgis.refr         net>
>              actions.net
>           cc
>      Subject
>              24.02.2003 15:04          RE: [postgis-users]
> Cygwin /
> installation
>              Please respond to
>              ; Please respond
>                     to
>                PostGIS Users
>                 Discussion
>              stgis.refractions
>                    .net>
> List and Christian,
> I am getting exactly the same results. Endless 'undefined'
> references in
> the linking phase (I think). I've tried all sorts of combinations of
> things that other users (thanks to Barbara Kastelliz for a
> brief moment
> of hope:) and the archives have mentioned over the last two
> weeks to get
> PostGIS 0.7.4 compiled and installed on Cygwin, but no luck.
> I managed to install PostgreSQL from the source, but only without perl
> (more 'undefined' references). I tried to install perl from source as
> the latest cygwin perl binary package (5.6.1-2) is built with gcc2,
> which I thought may be part of the problem. That was a complete
> non-event (don't know how many times I've now gone through ./configure
> and ./Configure scripts). Still no postgis. I've run out of ideas. If
> anyone has any more suggestions (I would love to just do it all on
> Linux, but I need it on WinXP), please let us know.
> Regards,
> Henry Holland
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of christian.schuster at rsag.ch
> > Sent: 22 February 2003 12:18
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Cygwin / PostgreSQL / PostGIS installation
> > Hi list,
> > I have a working PostgreSQL with PostGIS (CVS) support on my
> > local machine
> > (Win2000 Pro). Now I have a new installed Win 2000 Server
> SP3 on a IBM
> > Netfinity machine and I wanted to install there the latest
> releases of
> > Cygwin, PostgreSQL and PostGIS. Here is the problem. I cannot make
> > PostGIS-0.7.4. The error is:
> > What I did is the following:
> > 1.    I downloaded the latest cygwin release with PostgreSQL
> > including the
> > source:
> > 2.    I added DLLIMPORT to /src/include/ptimizer/cost.h.
> > 3.    I configured PostgreSQL LDFLAGS=-L/usr/local/lib ./configure
> > 4.    I made PostgreSQL
> >       Here I have many messages like the following on:
> >          make -C tcop all
> >          make[3]: Entering directory
> >          `/usr/src/postgresql-7.3.2-1/src/backend/tcop'
> >          gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations
> >          -I../../../src/include  -DBUILDING_DLL  -c -o dest.o dest.c
> >          -I../../../src/include  -DBUILDING_DLL  -c -o fastpath.o
> >          fastpath.c
> >          -I../../../src/include  -DBUILDING_DLL  -c -o postgres.o
> >          postgres.c
> > pquery.o pquery.c
> > utility.o utility.c
> >          /usr/i686-pc-cygwin/bin/ld.exe -r -o SUBSYS.o dest.o
> > fastpath.o
> >          postgres.o pquery.o utility.o
> >          make[3]: Leaving directory
> >       I just copied one out of them. But I guess something
> is not okay
> >       But  was suprised as at the end message came that
> PostgreSQL was
> > successfully made and is ready to install
> >          /usr/include/stdio.h: At top level:
> >          pl_scan.c:2384: warning: `yy_flex_realloc' defined
> > but not used
> >          -Wno-error  -I. -I../../../../src/include   -c -o
> > pl_handler.o
> >          pl_handler.c
> >          -Wno-error  -I. -I../../../../src/include   -c -o pl_comp.o
> >          pl_comp.c
> >          -Wno-error  -I. -I../../../../src/include   -c -o pl_exec.o
> >          pl_exec.c
> pl_funcs.o
> >          pl_funcs.c
> >          dlltool --export-all --output-def plpgsql.def pl_gram.o
> >          pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
> >          dllwrap -o plpgsql.dll --dllname plpgsql.dll --def
> > plpgsql.def
> >          pl_gram.o pl_handler.o pl_comp.o pl_exec.o pl_funcs.o
> >          ../../../../src/utils/d
> >          llinit.o -L/usr/local/lib -L../../../../src/backend
> > -lpostgres
> >          dlltool --dllname plpgsql.dll --def plpgsql.def
> --output-lib
> >          libplpgsql.a
> >          make[4]: Leaving directory
> >          `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql/src'
> >          `/usr/src/postgresql-7.3.2-1/src/pl/plpgsql'
> >          make[2]: Leaving directory
> > `/usr/src/postgresql-7.3.2-1/src/pl'
> >          make[1]: Leaving directory
> `/usr/src/postgresql-7.3.2-1/src'
> >          All of PostgreSQL successfully made. Ready to install.
> > 5.    I changed to the PostGIS directory and tried to make
> it with the
> > following error:
> >          $ make
> > -Wmissing-declarations  -g -I.
> >          -I../../src/include  -DFRONTEND
> >          -DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUS
> >          E_VERSION=73  -c -o postgis_debug.o postgis_debug.c
> >          E_VERSION=73  -c -o postgis_ops.o postgis_ops.c
> >          E_VERSION=73  -c -o postgis_fn.o postgis_fn.c
> >          E_VERSION=73  -c -o postgis_inout.o postgis_inout.c
> > postgis_estimate.o(.text+0x1380):/usr/src/postgresql-7.3.2-1/c
> ontrib/postgis-0.7.4
> > /postgis_estimate.c:743: undefined reference to `_nconc'
> > postgis_estimate.o(.text+0x1388):/usr/src/postgresql-7.3.2-1/c
> > /postgis_estimate.c:743: undefined reference to `_make_and
> >          s_explicit'
> > postgis_estimate.o(.text+0x1398):/usr/src/postgresql-7.3.2-1/c
> > /postgis_estimate.c:745: undefined reference to `_canonica
> >          lize_qual'
> >          collect2: ld returned 1 exit status
> >          dllwrap: gcc exited with status 1
> >          make: *** [libpostgis.a] Error 1
> > I looked in the archive of PostgreSQL and PostGIS and tried
> > several things.
> > But I was not able to figure out what I am doing wrong now.
> > Does anyone knwo where I do the mistake or what I forgot?
> > Regards,
> > Christian Schuster
> > Rudolf Schuster AG
> > Postfach 277
> > CH - 3000 Bern 11
> http://www.rsag.ch
> ++41 31 348 05 30
> postgis-users mailing list
