[postgis-users] compiling postgis with postgres 7.3 and cygwin
Klaus Benndorf benndorf at mail.bt-gis.de
Wed Jan 1 12:07:14 PST 2003
I tried to run your Makefile, but without the patches I still have the same
problems.
Do you know where to find them? They are not attached in
http://postgis.refractions.net/pipermail/postgis-users/2002-November/001793.
html
Thanks Klaus
----- Original Message -----
To: <postgis-users at postgis.refractions.net>
Sent: Wednesday, January 01, 2003 5:17 PM
Subject: Re: [postgis-users] compiling postgis with postgres 7.3 and cygwin
> Klaus Benndorf writes:
> > I tried to install postgis under Windows XP, following the "NON-UNIX
> > User's Guide". Everything worked fine and I had no problems with
> > configure and make of Postgres. But now make of postgis shows a lot of
> > undefined references. In the mailing list I found the hint, that
> > libpostgres.a might be not found, but it exists and I copied it to
> > different directories, that are definded in Makefile.
> > Any idea what to do?
> For some reason the PostGIS Makefile is not adding -lpostgres to
> the dllwrap command :-(
> The attached Makefile works for me
> also see
html
> for a required change to the postgresql source
> < although this mentions the 7.2.3 tree this still applies to the 7.3.x
tree >
> HTH
> Norman
> postgis-users mailing list
