[postgis-users] Select Query Performance
Riyaz Prasla riyazprasla at yahoo.com
Sun Jun 1 18:22:03 PDT 2003
  I am running Postgresql 7.2.3 on a linux Qube with
256 RAM. I have a table with about 100,000 records.
The table has a postgis geometry column. I have a GIST
index on the table on the geometry column. Here are my
questions:
1)When I do a spatial select query on the geometry
column in this table it takes a few seconds. What more
can I do in terms of the Postgresql configuration or
query tuning besides adding the GIST index?
Here's a sample query I make:
Select [column] from [table_name] where
[spatial_column] && [the geometry object];
2)Also, I execute this query over the web. If there
are mltiple select queries then I have to execute one
get its reultset and then send the other one. Is there
a faster way to execute multiple select queries over
the web?
Thanks in advance.
Riyaz
__________________________________
Do you Yahoo!?
Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
http://calendar.yahoo.com
