[postgis-users] Running createlang and postgis.sql
Paul Ramsey pramsey at refractions.net
Wed Jun 4 09:13:13 PDT 2003
I just grepped through the SQL files, and there is not an apparently
obvious location of an extraneous commit. I also checked an upload of
the CVS source against a 7.3 PgSQL and got no error like Mike reported.
Could you give us your relevant versions, Mike?
Thanks,
P
chodgson at refractions.net wrote:
> I don't know off-hand where the begin _should_ go, but an extraneous end/commit
> will certainly not hurt anything.
> I think the only reason for the transaction to be there is to cause either ALL
> or NONE of the postgis functionality to be loaded - otherwise it is rather
> painful to unload the half that got installed, and/or reload the rest, after
> you've fixed whatever problem caused it to fail in the first place.
> I don't have time to look at the code right now, but I think there should be a
> begin at the VERY beginning, and an end at the VERY end - with all the separate
> files for different versions and components, it is not too hard to understand
> why there are unmatched begins/ends.
> Chris
> Quoting Mike Leahy <mgleahy at fes.uwaterloo.ca>:
>>Robert,
>>You are correct about the commit.  I've found in the postgis.sql file
>>that I'm using there is an extraneous "end transaction;" about two
>>thirds of the way through the script (Line 761 of the attached file).  I
>>think that despite the lack of a matching "begin transaction;",
>>everything is working fine, but I don't want to find out later on that
>>I'm missing a bunch of the functions that are defined in this file.  Can
>>someone suggest whether I should add a begin transaction, and if so,
>>where should it go?
>>Thanks for the help,
>>Mike
>>-----Original Message-----
>>From: postgis-users-bounces at postgis.refractions.net
>>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
>>Ramsey
>>Sent: June 3, 2003 11:47 AM
>>To: PostGIS Users Discussion
>>Subject: Re: [postgis-users] Running createlang and postgis.sql
>>At a minimum we appear to have an extraneous 'commit' (or a missing
>>'begin') in the sql file which needs to be paired up. The other warnings
>>are normal and can be ignored -- when postgresql creates new types there
>>is a brief period of chicken-and-egg, when types have been created and
>>their constructurs have not, which raises a warning.
>>P.
>>Robert W. Burgholzer wrote:
>>>Mike,
>>>I just had the same question today, thanks for posting it. It seems
>>that all
>>>is right with the data import and I have successfully added data, and
>>>retrieved it via avpgcon. So, I would say, no, you needn't be
>>concerned,
>>>however, I am not the expert, thus all I say is speculation.
>>>Perhaps this is a newer, more extensive error condition being reported
>>by
>>>postgresql, are you running postgresql 7.3.3?? (I am)
>>>Robert Burgholzer
>>>>===== Original Message From PostGIS Users Discussion
>>><postgis-users at postgis.refractions.net> =====
>>>>Just a couple questions.when I run the command "createlang plpgsql
>>>>[DBNAME]" - I'm guessing that means the build that I got already
>>>>includes this language?
>>>>Next, when I run "psql -d independencia -f postgis.sql", I get the
>>>>following notices:
>>>>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index
>>>>'spatial_ref_sys_pkey' for table 'spatial_ref_sys'
>>>>NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit index 'gc_pk'
>>>>for table 'geometry_columns'
>>>>NOTICE:  ProcedureCreate: type box3d is not yet defined
>>>>NOTICE:  ProcedureCreate: type spheroid is not yet defined
>>>>NOTICE:  ProcedureCreate: type wkb is not yet defined
>>>>NOTICE:  ProcedureCreate: type chip is not yet defined
>>>>NOTICE:  ProcedureCreate: type geometry is not yet defined
>>>>NOTICE:  COMMIT: no transaction in progress
>>>>Is this an issue I should be concerned about?
>>>>Kind regards,
>>>>Mike
>>>_______________________________________________
>>>postgis-users mailing list
>>>http://postgis.refractions.net/mailman/listinfo/postgis-users
