[postgis-users] postgis and mapserver - queries
David Blasby dblasby at refractions.net
Mon Jun 9 10:24:32 PDT 2003
C F wrote:
> What does mappostgis.c do (I don't see it in my PostGIS source)?  I'm
> curious, because I'm doing some similar operations using the EXPLAIN
> VERBOSE method.  Without writing a full blown SQL parser, I don't see a
> better way.  It seems like the best way would be to hook into the
> actualy SQL parser being used by Postgres... but maybe that's too
> difficult and that could change as well.
mappostgis.c is part of Mapserver.  Part of its functionality is to
'query' for a layer.  Functionally it looks like this:
a. ask the layer for its columns
b. ask the layer to give you a feature with a specific id
It was orginally designed for Shapefiles, so this order makes sense (the
columns are known apriori).  Unfortunately, for DB connections, this is
backwards!
dave
